Pics of A/C 6 ft. rotary mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Topic: Pics of A/C 6 ft. rotary mower
    Posted: 02 Aug 2011 at 10:41pm
My brother was cleaning out a fence row for the farmer he works for.This is what they drug out.My brother knew I would want it so they called the owner of the land(who did not know anything about it)and he said for 50 bucks I could have it.My brother used their loader and loaded it on a wagon and brought it over and unloaded it at my place this evening(Good thing I bought extra hats at Dale's show).Tires are in bad shape and side metal is a little rough.Good thing it appears the gearbox is OK.I have a line on some tires like these and my brother said he could patch the metal with his tig welder.
Looks to be a newer model 172.Similiar to the older style 172 that I already have.No numbers or tags
Mike sky high baloon,I believe this is the same model you have.We had one just like this on our farm when I was a kid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 10:50pm
Nice find/save.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 11:21pm
Believe I have one nearly identical to it. First time I've seen one with chains hanging from the front
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 5:54am
Great find, Pat!
WC, CA, D14, WD45
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 6:34am
I also have one without the chain deflectors. This is something that I would like to find. If anyone has a mower with a bad gear box, I would like to buy the chain deflectors.  Dave.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 7:49am
Wow -- great find.  $50  well spent -- plus the hats. LOL.
tomwestky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomwestky Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 7:56am
I'd like to know the source you have for wheels for the mower.  I need some.
T. Westerfield
Crofton, KY
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 9:17am
Pat - nice!  I'd love to have those optional front chains!  You are missing the PTO shield from the pivot joint back.  I have regular tires on mine and already I'm tired of them going flat, lol!  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 9:22am
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 9:55am
Pat, nice find.  Wish I could get lucky like that.  A little TLC and you'll have a working showpiece.  Have fun with it.
Brian
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 10:09am
The problem areas are leaking bottom seal in the gearbox, due to material wrapping and sticking/worn plungers/bosses in the overrunning mechanism.  Last I checked the blades were still available.  Nice find!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 10:50am
I have a 3-point version of that unit and they are tough. The mounting holes front and back are where they simply added the brackets to make them a 3-pt. with adjustable tail wheel assembly. I use mine on a D15II and it will take down trees 3" in diameter with no problems. Even used it to break in the motor on the D12 by cutting with the 3-pt. arms used for front draft only in grass 4-5' tall. I changed the front seal in the gear box and run a combination of gear oil, strained motor oils and oil "honey" and it was the best 350.00 I ever spent. Heavy and thick blades that will really do some work when you get her wound up and she will make the gov'nr on my 15 bark in real heavy pastures.
With the small area for rear discharge, they will almost leave a windrow on the right side of the cutter when you get in heavy material. Check the retainer nut does not come loose on the front shaft out of the gear box (you need to remove the gaurd to check this and grease the uni joint anyway) and do not run the dampener spring made all the way up on the adjustment. PM me if you want a copy of the manual that came with mine.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 10:54am
Correction; yours does not have the gaurd installed and the nut I am referring to is for the yoke on the shaft, between the gear box and the slip clutch assy.
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 11:10am
nice find and a 50 dollar bill well spent.
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 5:12pm
great find, i have a old trail type woods 6 footer the left side is plum gone, the right side has maybe 15% of the metal left and it works great, actually with the left side gone it cuts and throws all the trash to the left and  i have baled behind it before and it does as good as a 6" cycle mower
the one you have looks like a new one next to my old woods
i like old tractors of all colors
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 6:03pm
Mike Here's a shot of your mower.
Don
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2011 at 6:57pm
Great find!! 50 dollars??? Lucky man!!
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
Larry@Yorktown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry@Yorktown Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2015 at 9:40pm
the chains really do the job.  mine has chains on the front and back.  came from the dealer that way.  looks like the mower would pivot better with the wheels forward.  mine has the wheels trailing behind.  mow closer to fences that way.  manual says finish mower wheels back, bush hog wheels forward....lucky my father in law had original owners manual for the mower and the D19.
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2015 at 10:14pm
Nice find. My brother picked up the 2 wheel 6' trail model last fall. It is in pretty good shape with chains and all. Works really good and as said before, it will take small trees. Believe it will be worth the tlc.
