Need seal #
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Topic: Need seal #
    Posted: 02 Aug 2011 at 12:54pm
Need seal no. for Allis C, goes on the tranny bearing carrier that the final drive shaft slides into.  Old one looks like CR 800351, but can't find it anywhere, may not be right no.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 1:33pm
You might get seals from Sandy Lake Implement without giving them numbers. I think it would be a lip seal. I have not heard of anyone making the leather seals.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 2:01pm
Dick has a point, although in talking with my SKF(owns chicago rawhide) rep, SKF does still make some leather seals. There are some applications in which leather provides the best seal
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 2:36pm
Thanks, will check with Sandy Lake. This didn't cross with SKF, thought I might have wrong no.
1C 1 WD45 1 AC180
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 4:32pm
Baum Hydraulics www.baumhydraulics.com has a good listing of seals by CR and National in section R of their catalog that you can download. I didn't find any very close to your numbers but they list them by number and by size and type.
Gerald J.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 6:58pm
Chuck
Sounds like you need the inner pinion shaft seal. Have tried "aftermarket" (auto store) cross referenced ones and found out they are pretty susceptable to damage when installing the final. Have had good luck with the AGCO ones (like SLI will provide).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 7:33pm
Thanks again, will check with SLI.
1C 1 WD45 1 AC180
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 7:57pm
  that number has been supereseded  like a lot of nubers are looking forhappens all the time sorr y boys for the info.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 9:01pm
You can take measurements (all dimensions) and call your favorite bearing and seal source. I've done that several times and have been able to find what I need.
WC, CA, D14, WD45
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 9:07pm
Chuck - give Keith at Maple Lane Farm Equipment a call 519 323 4289
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
