CAV injector pump on AC 170
Gary J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary J Quote  Post ReplyReply Direct Link To This Post Topic: CAV injector pump on AC 170
    Posted: 02 Aug 2011 at 10:19am
Hope someone can help me out here. I have a 1973 AC 170, was running at 1800 rpm when it died sounding like lack of fuel. Replaced fuel filters, bled lines and it would start for about 3 seconds and die. Bleed, start, 3 seconds, die, etc. Now I can not even get that, there are no air leaks that I can find. I was told the CAV injector pump return line is at the end near the timing cover, this is the only line where I get fuel! I get nothing from the line on the other end. Does not seem to have enough fuel at the injectors maybe, not sure. Any ideas? I was thinking the injector pump is bad, but if the fuel is routed wrong?
Any help is greatly appreciated and thanks.
Gary J
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 10:23am
The mechanical fuel pump (primer pump), may have died.  That happened on my 175 some years ago.  Got going quick with a new one.  No problems since then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary J Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 11:18am
Forgot to mention, it has an electric fuel pump.  There is fuel to the one line closest to the timing cover at the injector pump.
Thanks,
Gary J
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 11:57am
The line at front of pump is inlet Supply line! rear is return. If electric pump is working -supply of fuel to pump and you have fuel spraying out bleeders and your not getting any smoke or fuel to injectors. Something broke inside inj. pump! I can't remember the part that breaks, but it happens on them.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 12:34pm
the line near the mounting flange(front) is the RETURN! Inlet is at the rear, near injection lines. DPA pumps do not suffer from broken flex ring issues, you are thinking of Roosa pumps. Make sure your supply is good, as well as the return line not restricted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 1:29pm
We had a brand new tractor with Cav pump was running and it just quit like you shut it off. They found something broke inside the pump? It's been to many years to remember.
Ed is correct , Rear is inlet! I should have looked at book and not the tractor! As ours front line is going back into filter thats marked with out arrow? So I firuged it was inlet. and its been that way since new?
Edited by farmtoybuilder - 02 Aug 2011 at 1:47pm
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 2:08pm
 I have a NOS injection pump for a 170 and/or 175,  Part # is 255997.  Asking $500.00 which includes the shipping.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary J Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2011 at 5:09pm
Thanks for the help, I switched the lines coming from the filter and it started and ran.  Next question would be why!  What would change in the filter housing to make the fuel come from the opposite port?  Is this a temporary fix and should the filter housing be changed?
Thanks,
Gary J
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 10:06am
Update for future reference.  It was in the filter housing.  It would only run for about 2 minutes with the lines switched.  So cleaning, swapping out if that does not work, the filter housing.  Better that then the injector pump!  Thanks for the information.
GJ
