Can somebody get me part numbers for an Allis D14?
CarsonD14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CarsonD14 Quote  Post ReplyReply Direct Link To This Post Topic: Can somebody get me part numbers for an Allis D14?
    Posted: 01 Aug 2011 at 2:48pm
Hey there,
My bearing went out on my front right wheel.  I found an exploded view of the bearings, but I really need part numbers to be able to get the right one.  I would like the part numbers for the following parts on a D14 with wide front serial number 9108 (the parts are in order as they appear in the manual I have, starting from the outside and working in toward the spindle):
3. Bearing cone
4. Bearing cup
5. Wheel Hub
6. Bearing cup
7. Bearing cone
8. Seal retainer
9. Felt seal
Also, if anyone has any tips or pitfalls to avoid when I get to puttin' this thing back together, I'd appreciate hearing them!  Thanks!
Edited by CarsonD14 - 01 Aug 2011 at 2:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 2:58pm
Take the old bearings to your local bearing supply store, Motion Industries etc. They can match you up with new. I don't know if that felt seal is available anymore, many aren't. The hub I have no Idea about unless AGCO has one.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 3:00pm
go to AGCOCORP.com, parts and view as a guest. Search for D14 and then the part you need. The part numbers are all online.
The hub you will need to source from a used dealer or other type service
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CarsonD14 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 3:03pm
C Tucker,
Thanks, I'll try that.  I don't really think I'll replace the hub, but I did find one on a parts site, and thought that it might be cheaper to replace the whole thing.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 3:16pm
There are after market sets available on eBay; search "Allis wheel bearing". one found is below:
There are others available also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CarsonD14 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2011 at 3:35pm
Hey Charlie,
Thanks so much for the parts website, I got all the numbers I need, and now it's just on to finding the parts!  If it helps anyone else, here's the direct address to the site, so all you have to do is type your model and select AGCO Allis for the brand:
Thanks again!
Carson
