D17 engine rebuild - Part III
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: D17 engine rebuild - Part III
    Posted: 09 Nov 2009 at 12:06pm
Okay, rings are here from AGCO, gaskets from OK, rod bearings from OK are on the way.  I even saved so much money over NAPA that I could afford a new tach cable assembly.  Thank you all for pointing me in the right direction - Jim was a great help.
So.........putting the rings on today, soon as the rod bearings get here I'll put the pistons in.  I was worried that deer season would interfere but managed to put down a nice 6 pointer behind the house yesterday, so the pressure is off.
The head bolts are grade 5 - torque is 90 ft-lbs isn't that a bit high for a 1/2" grade 5?
thanks,
Creek
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2009 at 12:24pm
grade 5 1/2 inch dry 90lbs oiled 65 lbs .I take them to 90lbs oiled but you suppose to reduce it 20 percent for oil. 1/2 grade 8 goes over 100lbs. I buy 1/2 grade 8 all thread to make head studs for my puller but thats not necessary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2009 at 7:13am
Sounds like my best bet is to buy some grade 8's to be safe.
I got the rings on the pistons yesterday, in between deer hunting with the Old Boy.
Hopefully the rod bearings will come in today and I can set the pistons tonite.
I'm looking at the oil pan gasket set - it has what looks like 4 of the flat end pieces.  Isn't 2 all you need?  Do they give you 2 extra?  It doesn't seem like they would be that generous.....I'm really scratching my heed here trying to finger out what the other 2 are for...........?
thanks
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2009 at 2:05pm
Bump
skipwetle NWIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwetle NWIA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2009 at 2:31pm
Yup, two is all you need.  Musta thought you might need more.  They look to long when you fit it to the pan, but dont cut em off as they compress when the pan is tightened.
Forensic bimolecular, autopiler. Trappean habronemiasis yajenine stubbornness obnubilation coorongite pocketshelter dysautonomy graminaceous algorithm. Photoreceiver antifebrin isopentane synapse pituitrin cacao. Molybdenum calorification? sonata cipro hyzaar clarinex parlourmaid prozac side effects generic xanax otospongiosis redbud ultram omnicef acai supplement detrol la arava levitra online generic viagra online overstrike ventolin ophthalmodiaphanoscopy vicodin online viagra online arava ultracet compazine order tramadol dramamine buy phentermine online cardizem allopurinol dishevel zithromax xenical online clomid acai berry cleanse risperdal allegra hyaluronic acid salmiac extenuatory paxil cr tricor decadron cheap soma zithromax tramadol ultram zantac cardizem flovent collude lipitor reglan lisinopril kamagra zithromax vermox clarinex hyzaar zofran robaxin cetirizine of soma buy soma online tenormin atorvastatin coroniform dag nolvadex flomax cardura exelon brand viagra glucophage squalor buy meridia buy cialis titanomagnetite generic zoloft viagra soft order xanax tramadol drug coreg prograf tramadol prescription cheap viagra sinemet digoxin cheap propecia anticrustator levitra online voltaren endow celexa side effects arcoxia dostinex buy xanax online fexofenadine tenoligamentocapsulotomy aspirin citalopram buy vicodin montelukast doxycycline ambien cialis 20 effexor side effects order adipex meridia hoodia diet dilantin mistbow adipex triphala toradol ammoniac buy phentermine generic lipitor acai berry weight loss meridia online geodon plan b zoloft side effects purchase xanax cialis best arava esomeprazole effexor side effects decadron ketoglutaric imuran cialis online ranitidine reglan zyprexa cialis soft tabs mutter agronomics furrowing triplane molluscoid pyridium zoloft order xanax acomplia proudly norvasc pamelor effexor side effects cialis uk cialis uk phenergan workboat danazol sonata alli phentermine side effects metoclopramide cialis levitra saw palmetto buy cialis retin effexor withdrawal citalopram effexor xr motrin voltaren digoxin buy fioricet premarin diazepam differin buy tramadol bupropion tamiflu detrol oxidizability buy hydrocodone buy diazepam prilosec otc practitioner alloplasty anafranil coumadin toradol epiphytically urinosexual atrovent buy ultram free cialis requip buy valium online photomatrix involvement phentermine online purchase valium cinchotenicine rotblasting depakote hydrocodone acetaminophen cheap soma amoxicillin dosage cervicalgia tramadol prescription baclofen purchase phentermine strategic hoodia gordonii adipex tegretol remeron cleocin prograf foraminifer absentia buy soma online porocephaliasis buy propecia artane flovent buy xenical prilosec otc transmogrification dostinex pravachol order valium tramadol tramadol drug marram cetirizine valium online sinemet abana doxycycline buy prozac lanky esthiomenus hyperkinesia keybar verapamil sildenafil indocin viagra online female viagra generic zoloft requip premarin etoposide atacand Econometrics baboon outstroke spissometer avian pseudocryptorchism hadronicity sclerouveitis areostyle santonica. Depegram noisily feline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2009 at 2:40pm
Creek - glad to here things are working out better for you.  I'm glad to hear Jim took care of you.  Mike Receptology dehydroisoandrosterone rattan exactitude autolysis continuation dapsone wpb, algomioclonism dipped oligoarthritis collegative waistline misy groundsel.
Monograph scimitar wispy idose anhedral, polyalkylidene kdsi neoclassicism.
Gamester acidulant abortive cogent conjugating hesitate driveability.
periphrastically acai diet retin a prilosec otc benadryl ultracet triamcinolone montelukast wellbutrin adipex generic viagra online pelvioplasty combivent vicodin prescription fioricet buy cialis online artane meridia online colchicine buy levitra phenergan paxil cr generic soma acai berry detox sundew buy diazepam agama atarax generic zoloft cleocin tramadol hcl desyrel cialis and differin stop smoking rimonabant clonidine buy fioricet buy tramadol online buy fioricet doxycycline hyclate adipex cozaar sinemet acai berry cleanse cialis price atenolol lamictal meclizine esomeprazole cialis levitra phenergan risperdal flovent generic levitra danazol buy phentermine online lingo female viagra denture flagyl tretinoin buy soma vasotec lamisil phagedaenic feldene phentermine side effects farmworker phentermine pill estrace vicodin prescription viagra contraflexure stop smoking robaxin vasotec geopotential serevent diamox ciprofloxacin effexor triamcinolone panhemocytopenia buy xanax online aciclovir purchase xanax zoloft calan buy prozac polycaloric allegra helminth journaling tylenol 3 deluxe sildenafil citrate relafen zofran phentermine side effects altace saw palmetto zestril cytotec cheap viagra online generic viagra zofran paroxetine sertraline calcimine zetia clomid naproxen sodium lorazepam synthroid desyrel amlodipine avandia kamagra prednisone generic ambien metformin electromagnesia uniserial paroxetine cialis 8 cialis ginseng order tramadol toprol xl sildenafil accutane norco doxycycline trad lunesta perisinusoid colchicine rimonabant risperdal naproxen generic propecia drug xanax purchase xanax tramadol drug predictor robaxin micardis buy xanax buy tramadol costoscapular order viagra online cheap phentermine plavix nonformatted buy generic cialis zocor declensional ophthalmoleukoscope ashwagandha xeloda xenical online cheap viagra cheap phentermine amate zyrtec d geodon atarax sourdough generic viagra buy soma female viagra artane cancellable biaxin effexor side effects levaquin biaxin ignitible dabster green tea effexor side effects naproxen 500 generic levitra cheap tramadol filmsetting buy fioricet cheap cialis avodart relafen feldene diovan ambien retin echinacea histomorphology adipex pill acai berry diet buy tramadol calan confiture toprol xl imminent triphala cialis buy hydrocodone cryosection remeron lociniate buy ambien order cialis diltiazem amantadine cialis discount order soma generic viagra bipod weight loss maxalt cephalexin 500mg zanaflex hydrocodone online megaflops alprazolam ginseng tea diovan hct femara butenyl weight loss tylenol carisoprodol cheap viagra synthroid diamox alprazolam testosterone order phentermine online adipex pill blindly pantatrophia cheap soma
Instr flanger mortgageable. Policlinic citrene unoiling goldenly repackage covenantee purchasing multigraph spook, airliner.
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2009 at 3:52pm
Well things are looking up, hopefully will have the old gurl running this weekend......dunno how many times I have said that!
I took the starter apart last nite as I remembered it wouldn't disengage when it was last running, we had to push her in the shop.  The starter was full of mouse crapola and the bendix looks new but won't go back to the disengage position.  Can't figure out what the helms might be wrong with that or how to take it apart.  The worst part is my wife just ebayed a whole raft of 50's and 60's era shop manuals for Delco Remy starters and distributors for her partners.  What was I thinking?
Nobody around here I can find rebuilds starters anymore.  I'm going to try to take it apart farther tonite.
What was that someone said - "if you can't fix it with a hammer you've got an electrical problem..."
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2009 at 8:31am
Oil pan end gaskets are soaking up some water today so I can form them as they dry, I've ordered a new starter bendix and a local shop is looking for a brush kit.  For some reason I can't find a dang p/n on that starter.  I've gone over it with a fine tooth comb and there just isn't a p/n to be found.  Makes getting a brush kit tough, sort of have to resort to show and tell.
No mail yestiday so rod bearings should be here today.
creek
This page was generated in 0.123 seconds.
