D15 diesel engine
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: D15 diesel engine
    Posted: 27 Jul 2011 at 10:18am
we have a customers  AC forklift with an engine same as D15 diesel that has major problems - any salvage units out there with crank and block good?  bgequipparts@yahoo.com   or 731 642 1242
MarkinSIndiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkinSIndiana Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2011 at 1:20pm
Try this Ebay seller odd_ball_autoparts they did have a rebuilt D-175 (D15 diesel) for around $2700 complete TX# (217)-422-0315
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkinSIndiana Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2011 at 1:24pm
Also I know it is not recommended but Republic Diesel in Louisville Ky. rebuilt (welded and resized) a crank for me 30 years ago and it is still going strong
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2011 at 9:40pm
The 175 diesel is a Perkins and is differant from the D15 in both size and design
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2011 at 11:24pm
Joe I think Mark is talking about the cubic inches, not the tractor model.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkinSIndiana Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 7:04am
The D-175 engine was the diesel engine model number for the D-15D and HD-3s, the number was from the cubic inches 175 of them it is actually a Buda desgin Lanova type Diesel ( Injector sprays into a power cell instead of dierectly down on the piston) The biggest problem for these engines was if they got overheated the heads had a bad tendancy to crack, also this engine is a 4 cylinder version of the WD45D D-17D and D-19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 9:21am
Yep, the 175 cid diesel as used in the D15 is basically a 262 missing 2 cylinders. They use the same pistons and sleeves. I'm pretty sure the bearings and connecting rods are the same too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkinSIndiana Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 9:24am
Yes, same bearings, sleeves, pistons, rings, conecting rods, power cells, etc just uses 2 less of everything
