8070 SEAL |
BStone
Topic: 8070 SEALPosted: 25 Jul 2011 at 4:40pm |
Mack...Dr.Allis or anyone.8070FWA imput shaft seal leaking.Input shaft has a few small grooves in it.Looks like someone turned it with a pipe wrench or something.Do they make a speedi sleeve for it? I think it will be ok after polishing it out but want to make sure while I have it split.Thanks to anyone that can help.BStone
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2419 |
Posted: 25 Jul 2011 at 10:32pm |
Power shift? If it is, then yes a speedy sleeve would work .Just need the diameter of shaft and you should be good to go.The trick will be to install it on the shaft with some sort of driver.Good luck.
