Question on turning cylinder bars on an M combine
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Question on turning cylinder bars on an M combine
    Posted: 24 Jul 2011 at 8:08am
I am going to turn the cylinder bars on my M combine.  I want to put in a St. Johns enclosed cylinder in it, but I a kind of waiting just in case I find a nice, low hour M2/3 or L2/3 combine to upgrade to before next year.  My question is, do I have to put in new hardware, or can I use the old bolts?  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2011 at 8:35am
Use the old bolts unless the heads are worn to where you can not get them out.   MACK
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2011 at 10:43am
Judge for yourself, but you can also drop the complete assembly out the bottom and turn it around.  You do need to remove the bearings and shafts from each end to do this, but it will stay in balance.
This page was generated in 0.104 seconds.
