One-Sixty Questions
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Topic: One-Sixty Questions
    Posted: 16 Jul 2011 at 9:59am
Dad and I are looking at a One-Sixty.  I've been doing some research and have called the local dealer.  I know there were both the basic and standard version.  I believe this one is a basic because it has the 6 speed and only a foot throttle.  Can a hand throttle be made or can parts be found to adapt it over?  I need to check to see if it has power steering.  It looks like it does from the picture.  It seems to be a pretty nice tractor. What are your thoughts and opinions?  I know only 4,000 or so were made.  If we buy it we would probably use it on the grain drill, 4 row corn planter, and to rake hay. Thanks for the help.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 10:07am
Also what do you guys think it's worth?  It has 3900 hrs.  Thanks.
Flyer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 1:07pm
The one in the picture definitely has power steering.  I didn't know you could get one without the hand throttle.  Finding parts for them is a bit of an adventure since they don't share many parts with the other tractors in the 100 series.  I've manged to find some stuff on ebay for mine.
An optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer sees a glass with double the required capacity.
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2011 at 1:24pm
double check about the hand throttle, lots of folks just used the foot throttle and they would set up. when you went to use them they would break off. have seen several like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 7:59pm
Thanks for all the replies.  Today we went and looked at the One-Sixty.  Since we had a clue what to look for we were able to see that the hand throttle was broken off.  It does have power steering and the 10 speed transmission.  After checking it over and test driving it we decided to buy it.  Going to pick it up when dad gets home from Hutchinson.  Thanks again for the help.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2011 at 8:41pm
You'll like that perkins engine, Dad scrapped out a 160 about 10 years ago. It needed transmission parts that are no longer available. He put the engine in his old Ross forklift. Still starts and runs great.
If you give it tlc it should be a good tractor for you.
Tell your Dad that i am going to Hutch Hope to see him there.
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2011 at 6:15am
Dave,  I will let Dad and Uncle Mike know to keep an eye out for you in Hutchinson.  Wishing I could have went but someone has to take care of the cows.
