Replacing crankshaft seal
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Topic: Replacing crankshaft seal
    Posted: 13 Jul 2011 at 11:08am
Like a lot of older tractors, my WD leaks oil. It's not bad, but still it's not nice on a garage floor. I keep cardboard beneath it to soak up the oil.
But my question is whether or not I can replace a crankshaft oil seal without pulling the engine. I just assumed it meant a total dismantling which, in my case, I'd probably rebuild the engine while I'm at it. But that costs money and time.
So, can I replace either the front or rear crankshaft seal easily?
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 1:18pm
To replace the front seal, you should pull the timming cover, then center it on the crankshaft when going back together.
To properly replace the rear upper seal you need to remove the flywheel, the lower is in the rear main bearing cap.
It would be easiest to pull the engine for it all.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 8:05pm
  have replaced many seals just remove frt. pullypull out seal an install a new one
