200 hyd question.
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Topic: 200 hyd question.
    Posted: 11 Jul 2011 at 8:07pm
I am pretty sure I know where this is leading, but I will ask anyhow. The hyd remotes and steering are very slow. Wont respond until rpms are at least 1800. I assume they both run off of one block in the hyd pump. Is there any hope for the pump. Stuck valve in there maybe?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 9:58pm
It could have seals blown on the inside, but if it has alot of hrs. on it most likely wear.
   MACK
