Bad Day!!!
dbounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbounds Quote  Post ReplyReply Direct Link To This Post Topic: Bad Day!!!
    Posted: 09 Jul 2011 at 9:34pm
Loader snapped while hualing hay
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 9:36pm
Sorry that happened to you!  Bad day indeed!
Greg Kroeker
fordf350dually View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 9:48pm
the only good thing is now you have a reson to do some resteration if you so choose.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 9:55pm
Glad you were not injured.  I would have had to go and change my shorts after that.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 9:57pm
   Ouch ! Did it take out the radiator ?
http://www.rumelyallis.com
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 10:11pm
Yikes, hope you are o.k. Nothing some welding and body work wont deal with. Get some rest and youll have it fixed in a day or two, good luck, TREV.
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 10:16pm
sorry to hear what happen. same thing happen to me about 20 years ago . I put a 1/2 in plate on both sides and welded it and still useing it today
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 10:55pm
As long as your not hurt, its a great day. And now you have a great reason for buying yourself a "NEW" Miller Wirer Feed Welder. I love my Miller. It makes even my welding look good.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 10:58pm
not good,hope you get it going again soon!
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 11:07pm
As long as you're not hurt...then its just troublesome. Beats pain any old day!
 Broke pretty neatly..weld it and then weld a nice brace on each side. Repeat on the other sides  lift arm and it'll be stronger than new.
 My old 4500 Fword backhoes all had welds and plates in the same location as that.....lotsa stress there.
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2011 at 6:26am
That was a big problem with early Ford TLB's.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2011 at 8:12am
Looks like a larger cylinder might have been the culprit.
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2011 at 8:27am
Sorry to see that happen to you. Good luck in fixing that and just be glad no one was hurt.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2011 at 11:06am
I never knew a trip bucket loader would fit on a 190. Those were built for a 400 lb bucket full of manure or snow. Bales are probably a little out of their league unless they are small ones.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2011 at 11:19am
I have broken loader arms before but the big drop was when I was dumping my 1 ton Chevy loaded with sand using my 580 CK Case backhoe, I chained to the front frame and stood the truck on end. When the rear wheels started to lift off the ground, this time, the one hydrulic cylinder ram broke and dowm she came.  The bucket dropped with the truck and stayed about two inched above the hood.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2011 at 12:16pm
I'm not seeing that... I'm seeing a weldment fail on the RH arm's dog-leg, starting at the top, and extending to the bottom... then the bucket fell, twisting the RH side.
If there WAS a larger cylinder installed, really wouldn't change the condition- if that weldment was 'right', it would have been AT LEAST as strong as the tube, but the weld clearly wasn't.  Tube should have bent before that joint failed.  A good engineer would have cited the lack of a secondary plane of weldment to extend the support zone up the tubes each way at LEAST as far as the tubing is wide or deep.  In all reality, the butt-weld isn't a good thing to rely upon under any circumstance other than direct compression.  The flexing moment under this application is high tension at the top of the joint, bending moment in the middle, and compression at the bottom... totally unsuitable for providing appropriate SF for this geometry.  Note that since this one couldn't have been welded from the INSIDE of the tube, weld penetration really won't assure 100%... and incipient cracking probably started long ago, after moisture got in there and corroded and froze-cracked it a tiny bit more at-a-time, it finally found it's failure point.
I would certainly use this as an excuse to get a really good welder (ANY excuse is a good excuse to get a good welder), but in this case, I would only use the wire-feeder to 'tack' pieces together.
Specifically, I would grind both faces to smooth fit, and chamfer all four sides to get as close to 100% as you can get... then fit 'em close, tack 'em with the MIG, then put in a two-pass bead with 1/8" E7018, first slow at 95A, and second faster at 110A.  After cooling, I'd grind the side faces so that a 3/8" or 1/2" splice plate would lay flat on each side of EACH arm, tack 'em in place with the MIG.  I would FINISH weld the gusset/sideplates on with 5/16' E7018 at about 130A...
Then I'd take it out in the field somewhere safe and TRY TO BREAK IT...
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 12:00am
Ouch Doyle!!!
Glad no one was hurt. Good thing it did not go under the front axle and bend alot more. Did you get jolted pretty good ?
Take care and hope you can fix it OK.
Take care, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2011 at 9:17am
there is nothing wrong with MIG welding the entire repair. Tensile strength on 7018 is 70,000. Tensile strength on ER70s is 70,000.
