Allis Chalmers C Distributor
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers C Distributor
    Posted: 09 Jul 2011 at 3:20pm
Hey guys I'm getting ready to put the distributor back on my Allis C and was wondering if I had to time it. If so how would I go about doing this? any information would be helpful. Thanks Blake
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 3:55pm
Yes, it must be timed. Ideally you should have kept exact track where the rotor was pointing when you took it out. Now you need to find TDC on compression stroke for cyl# 1. Pull the plug and put your thumb over the hole and turn the engine. When air pushes your thumb out, roll the engine by hand until TDC appears in the timing window. Drop the dist in with the rotor pointing at the post for #1 plug. I like to put my spark tester in the #1 wire and slowly rotate the dist until a spark jumps. The instant the spark jumps, stop turning the dist and tighten the clamp. The timing will be close enough that the engine will start and not kick back. Hook up your timing light and set the timing. I usually just do it by ear.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 6:32pm
What Brian said with the added point that when you set the rotor to number one terminal you tighten it down with the points just ready to open. You can turn the distributor back and forth before you tighten it to see the points are about to open.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 6:41pm
Eons or less ago it was standard procedure for timing a vw air cooled engine with a test light across the points. Set the crankshaft pulley ignition notch to the split in the crankcase (a bit before top dead center as I recall), and then turn the distributor case in the opposite direction the rotor turned and when the points opened and the test light came on, tighten the clamp. It was timed.
Gerald J.
This page was generated in 0.131 seconds.
