wd repower
fordf350dually View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Topic: wd repower
    Posted: 06 Jul 2011 at 4:59pm
 i was thinking about it and wondering what the biggest motor is a can easily repower with. i no its rarely easy but i just mean what is do able with the skills of putting a 350 in an s10 blazer. ( doesnt take alot of skill just finess and welder but still)
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 5:11pm
When i was a kid Dad and Nevin Tasto did the Carroll County 4H Tractor saftey program at our shop [Wertz Farm Equipment] The older guys that were already certified needed a project awile Nevin held the class for the younger ones. Dad had a WC with a blown motor and A 1959 Plymouth 318 and automatic transmission. The 4H guys with Dads help put the 318 in the WC with hand brakes. It had both the allis transmission and the automatic transmission. It was a lot of fun but never finished enough for tractor pulling.
The answer to your question is YES how much do you want to spend.
The universal answer to all questions is yes, how much do you want to spend?
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 5:39pm
I think repower was popular many years ago before they starting really pumping the power out of the stock blocks. When Ms are up to 150-200hp @2000rpm it doesn't make much sense to repower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 6:50pm
Theres been a few 292 Chevy transplants. Speed, or in this case, power is just a question of money. How fast, or powerful can you afford to go?
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 7:06pm
how about a 433i?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 7:40pm
Anything is possible
[TUBE]8LXFSLK3otM&feature=related[/TUBE]
Charlie
maurice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 8:19pm
What do you want to do with it?  I searched here a few months ago and posted some questions.  (I must not be using the correct search words...)  For instance, I found examples of a chevy smallblock fitting in the frame-rails of a WD, with minor notching.  There is a way of making a plate to match the engine to the WD trans, and using the WD clutch.  This method is reported to drive too fast for tractor work, but great for pulling.  On the other hand, as mentioned above, putting a trans between an engine and the WD trans should allow for gearing to do tractor work.  When I get some other projects done, I plan to try to modify a Dodge New Process 436 mated to the WD trans, and use a Dodge engine (I already have these parts, otherwise I might try a different brand.)
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 8:41pm
I believe some gleaner combines were powered by chevy engines. It might be worth looking into whether the backing plate would work on a wd. it would make things simpler.
Tramway Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tramway Guy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2011 at 9:19pm
The chevy engines were just a long bell housing that ended with a double V-belt pulley.  No correlation to a WC/WD bell housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2011 at 9:41am
i know nevin. he's a good guy. well money is not the issue. more tim. i work 12 hour days how ever i make bank doin it. i want something thats cool at a show and i can pull a wagon once and awhile. i showed up a stock m pulling big bail with it last year. i was in road gear and he had to run 2nd wat wqould be a good option
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2011 at 2:10pm
I have a friend that put a couple of 353 Detroits in a couple of WD45's. THey are load and smoke a lot but they pull like a team of mules.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2011 at 2:16pm
I wouldnt mind that but i think they are hard to come by in my area.
jnicol6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnicol6600 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2011 at 2:27pm
It would be neat to see one with a 4bt cummins out of a bread truck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2011 at 3:20pm
how about a 6.9 idi like wats in my truck. but will a 301 work resenably?
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2011 at 4:44pm
Friend has a little Detroit in a Franklin skidder I imagine he would part with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2011 at 7:34am
ya but if he is close to you thats quiet a trek when ur truck gets 9 mpg and ur on the otherside of the country
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2011 at 10:18am
8V71 detroit and I happen to have one I will part with LOL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2011 at 10:33am
Something else to think about is what are the rules where you plan to pull it. Seems like someone did the 292 Chevy 6 when their association altered it's rules to favor some Oliver guys. They didn't realize that change allowed the A-C guys to use the Chevy 292. Just something to think about...
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2011 at 4:45pm
Will  292 fit pretty easy?
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2011 at 9:34pm
I kindas thought this was so cool I borrowed the picture for insight on what my next pulling motor might look like.
Edited by mlpankey - 08 Jul 2011 at 9:34pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 4:28pm
MerCruiser 140hp Chevy 181ci with a V8 cylinder head?
I was thinkin' mebbie a Waukesha 7042, connected to the stock rearend by a really, really, really big clutch and driveshaft...
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 9:41pm
wat kinda motor is that. that thin look cool as well i dont wanna say it and get kicked or something but that thing is alsome. and how would a 2.8 chevy motor be. i have one. like could i build it you think.
This page was generated in 0.056 seconds.
