wd stuck in gear
mnhorseman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnhorseman Quote  Post ReplyReply Direct Link To This Post Topic: wd stuck in gear
    Posted: 04 Jul 2011 at 4:58pm
my wd stuck in a gear today will not go back to neutral is there a easy fix i have my mounted picker on it for parades so do not want to take it all off if possible thank god i got it on trailer but now can not get the damn thing off and have another parade wen
dsday and sunday any help is greaty thankfull for
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 5:53pm
Pull the shifter boot off, then the snap ring, than the washer, now with a long heavy duty screw drive and a flash light find the shift rail that is not lined up with it's notch in the center with the other rails snap it back to the center condition. put shifter back in, than stamped washer, than snap ring, than the shifter boot....all done.
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnhorseman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 8:32pm
Thank you,,,,,,,,,,,,, all done and the old girl is off trailer and in the shed once again thanks for the info wish everything worked on first try lol
