Petronix Flamethrower Coil
CORY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORY Quote  Post ReplyReply Direct Link To This Post Topic: Petronix Flamethrower Coil
    Posted: 27 Jun 2011 at 10:01am
I have already installed the Petronix Ingnition and am going to put on the "Flamethrower" coil.  They have a couple of different options being oil or expoxy filled.  Which one should I use?
Thanks
Tripp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tripp Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 11:21am
I replaced mine too, i went by their recommendation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 11:37am
I have the oil filled versions on 2 tractors. You need to make sure you get the one with the correct primary resistance. Too low and you'll let the smoke out of the module. I'm pretty sure the resistance for a 4cyl eng on 12V is going to be 3 ohms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 8:12pm
Either work well. I would go with the oil filled unit myself. Brian is right on with the ohm rating also. Get the 3.0 ohm rated coil for the four cylinder engine. We carry the oil filled 40K Blaster version in Black or Chrome.
Steve@B&B
This page was generated in 0.617 seconds.
