7045 air conditioner
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Topic: 7045 air conditioner
    Posted: 27 Jun 2011 at 9:12am
how much 134 a goes in a 7045 unit
 Shawn
190XT,D17and 7045
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 1:18pm
If you have a scales i think its 3.5 lbs. somebody should chime in.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 2:03pm
ok i tried 2 12oz cans and it got warmer lol now what ?
190XT,D17and 7045
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 3:22pm
Do you have gauges on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 7:39pm
What have you done so far? You have to remove all of the R12 first and evacuate the system. Typically a system converted from R12 to 134 will be 60% to 80% of the original R12 capacity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 8:04am
Brian the system was already changed over and it was not blowing cold air  and  i added 2 12 oz cans and now its warmer . i have no gauges to put on .
 Shawn
190XT,D17and 7045
denny sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote denny sd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 8:28am
Have you checked to make sure the heater is  shut off, cable comes loose on top of cab.  Sounds like your over charged condition.   It is easy to over charge with 134.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 12:04pm
At this point, you need to recover the system and recharge with a known amount. You need a gauge set to see whats going on. Low charge is just one of several causes for poor cooling. A fan clutch that free wheels too much, radiator and condenser clogged with chaff, stuck thermal expansion valve are a few that come to mind. You're pretty much stuck taking it to someone with a recovery machine and gauges to get it working now. Don't just vent it off. If the system is discharged too fast, the oil goes out with it.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 3:06pm
I thought R134 was safe for o-zone?
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 3:27pm
so the gas has to come out not the liquid?  if i would get a gauge, what pressure should it read to be good ?
 thanks Shawn
190XT,D17and 7045
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 4:56pm
Are you sure the compressors still running? You might look at the front of the clutch and make sure.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 5:12pm
 Shawn
Shawn,
If you can wait 'till next week, I would be happy to come and give you a hand. I just struggled through one of these sucessfully. I have the gages, recouvery unit, scaled, etc. Really, w/o these and a little knowledge you're just wizzin in the wind. I'm not lookin' for money, maybe a free beer!
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 9:07pm
Its supposed to be less harmful to the ozone layer. The EPA still says you're not allowed to just vent it off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 9:14pm
 thanks Shawn
All of the refrigerant that is in there has to come out. The way A/C works is the change of state of the refrigerant from a liquid to a gas. As the refrig evaporates in the evaporator, it gets cold. Sounds like Lou can help get you on the right path.
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 3:15pm
Lou that sounds great plz give me a call anytime  i work 5pm to 5 am  and i farm all day so anytime is good  Shawn  724-255-9904
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 6:06pm
Lou that sounds great plz give me a call anytime  i work 5pm to 5 am  and i farm all day so anytime is good  Shawn  724-255-9904 begin_of_the_skype_highlighting              724-255-9904      end_of_the_skype_highlighting
OK, it's a little hard to call right now, I'm working in Asheville NC, but I'll be back Friday. I'll call ya.
I live near Intersection of 18 and 30
Wait for the Lord;
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 8:19pm
my experience with ours is 3-4 cans.  but should have seen a little cooling with 2.  Maybe it is running out as fast as it is going in.  time for guages on the system.  if overcharged, your high side press will go extemely high and something could blow.  But I feel 2 cans just isn't quite enough yet.
