WD/WD45 Side dresser part
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Topic: WD/WD45 Side dresser part
    Posted: 20 Jun 2011 at 6:12pm
I cant seem to find any more than 3 of my bolts that attach the sprockets to the drive wheels.  Anyone have some they don't need?  I guess I need 5.  Is there anything that I can use in their place?
I can probably weld a couple nuts to a bolt and blacksmith something together to get me going, but nothing fits quite like the proper pieces....
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 10:11pm
I made the first set for mine out of the wheel bolt welded to a long nut and then just cut it off to the right length. After I made a set then fond the set that came with the side dresser.lol
Don
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 7:17am
The picture looks like a rod coupling with a short piece of threaded rod in one end of it.
Rod couplings are easy to come by.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2011 at 9:36am
Its the same threads as wheel lugs on a WD45 with the taper to fit the rim.  Then its drilled and tapped for a different bolt on the inside.  Its hard to see in the picture.
