D17 SIV 3 POINT DRAWBAR
Hardway(WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardway(WA) Quote  Post ReplyReply Direct Link To This Post Topic: D17 SIV 3 POINT DRAWBAR
    Posted: 17 Jun 2011 at 8:18pm
I am converting my snap coupler to a 3 point set up. I am all finished except the drawbar. I have the 3 point drawbar, but I cannot find in my parts or shop manual, a picture of how it is supposed to be attached. Does anyone have an picture or drawing of how the drawbar attaches underneath the tractor and could share here? Thanks Chris.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 8:30pm
I think you need a bracket where the pedals mount.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 8:31pm
Sorry for the crappy photos, not the easiest place to take pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2011 at 8:34pm
Let me try this again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardway(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2011 at 11:40am
Thanks for the photos Claus. I do not have this bracket, anyone know if they are available, say at Cook tractor or otherwise?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardway(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2011 at 12:33pm
Here are some pics of what I have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2011 at 12:49pm
My photos are of my 170, I would think the D17 is the same.  Is there anything wrong with leaving your Snap-Coupler drawbar the way it is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardway(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2011 at 4:35pm
My only issue is the 3 point drawbar is a little longer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2011 at 5:43pm
I doubt it.....the length of that SnapCoupler drawbar is accurate for any 540 PTO powered equipment and the three point hitch drawbar would/should be the same. This way, if you use the 3pt hitch you may have to slide the snapcoupler drawbar out and off the tractor so it doesn't interfere with whatever it is you have on the 3pt hitch.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2011 at 7:03pm
Like DrAllis says,  the length of the drawbar is correct, ASAE Standard,  height is also correct, both in relation to the end of the PTO shaft.  There is nothing wrong with running it that way.  With a 3-point drawbar you can further and deeper into a mudhole.  The Snap Coupler will help stop you so you won't get into too much trouble.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2011 at 7:43pm
Hi: I have the original bracket that bolts under the tractor that bolts on with 6 bolts. The brake   rod goes thru it and the draw bar has a hole in the back. Let me know if intrested. 785-353-2392 Thanks
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2011 at 9:40am
The 3 point version drawbar is longer by look of the eye. It mounts further ahead on the tractor though. So in the end the drawbar hole is in the same place no matter which style you use.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2011 at 10:27am
and....you will have to find the correct drawbar, which may be hard to find. The 3pt drawbar has a big bend in it.  Did you get the steering fixed??
ALLIS EXPRESS!
This year:
This page was generated in 0.168 seconds.
