D17 tach question |
Post Reply ![]() |
XT in pa ![]() Orange Level ![]() ![]() Joined: 21 Apr 2011 Location: hickory pa Points: 711 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Jun 2011 at 12:04pm |
i put a new tach and cable on my 17 . if i put the cable in the tach drive (distributor side) first and line up the key thats on the cable with the drive then put it in the tach it willonly work for a little while and then the key slides out of the drive. i can take it apart and put the key in the drive and not even an hour it comes back out. my question is ,is there a part that goes in the back of the tach and the cable goes in to space it out a little bit? this part would have to have o female and male square on it?
thanks Shawn
190XT,D17and 7045
D17JIM ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Points: 340 |
On my series II there is a little plastic do hicky that goes on the drive and the cable sticks into. The tack end if I remember right just goes into the tach. Then you just screw them down. The plastic piece is a very pricey piece. Got mine at Agco.
well Jim i looked into that with Brenda at sandy lake imp. and she sent me two different pieces but they are if you dont have the key on the cable and mine does so they wont work
190XT,D17and 7045
Henry se/k! ![]() Orange Level ![]() Joined: 08 Mar 2010 Location: Kincaid Kansas Points: 403 |
Sounds to me like the cable core is to short for some reason!
it measures 52 1/2 like i was told by sandy lake thats why this dont make sence to me.
190XT,D17and 7045
David(Stockbridge)MI ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Stockbridge MI Points: 536 |
Sounds like inner cable is to short or the outer to long. The ones we sell for the D17 are 56" long and have the metal key crimped on one end. the dist end will accept about 3/4" and the tach end about 1/2". David www.djstractorparts.intuitwebsites.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler |
You have me looking now. I got out a new cable made by KC speedometer. The end with tang will not recede into housing. A nylon washer makes it stick out about 3/4 inch. The tact end sticks out 1/2 inch. If washer is missing cable could work in to tack.
Post Reply ![]() |
