WD45 final drive
WhiskeySup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WhiskeySup Quote  Post ReplyReply Direct Link To This Post Topic: WD45 final drive
    Posted: 06 Jun 2011 at 1:14pm
 Is it normal to hear the final drives while driving. Mine makes a low growl sound. Have plenty of oil in the trans.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 6:34pm
The "final" drives are the big bull gears powered by the pinion gears off the differential ouput shafts.
So.........you may want to pull the plugs on the final drive pans to see if they are full.
A certain amount of whine/howl is normal; especially on a tractor that has been really worked over the years.
RickUP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickUP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 7:02pm
I bought a '53 wd-45, and changed all the fluids, and found no metal shaving. There is a gear noise everytime I work it. I'm not worried about it. If you hear growl and grinding then check fluids for metal. You don't have to drain all of it to check. Good luck.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 8:10pm
Yes, when I work mine hard I can hear a gear whine to. Guy who used to work where the tractor was bought said they did that even when new.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 9:05pm
My WD 'sings' pretty well, too. It has not gotten any worse in the ten years that I have had it. It seems quietest in 4th, which it doesn't get into very often, only when goin' for the mail!.
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2011 at 9:45pm
My WD45 also does it, it is full of oil and there is no metal shavings.
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 1:17am
My does it once in awhile. mostly when just driving it down the road..it comes and goes..
Post Options Post Options   Thanks (0) Thanks(0)   Quote WhiskeySup Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2011 at 8:43am
Many thanks for the feedback-puts my worrys to rest. This is my first tractor and with a limeted budget I cant afford major repairs.
