belly mower options for A-C C
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: belly mower options for A-C C
    Posted: 02 Jun 2011 at 8:32pm
Just priced a woods l59,, $3500 !!!!!  Is there anyone else that still makes them. I think there was one brand called  "sun-----" something, cant remember. Does anybody make a belly flail or rotory cy or si type? Thanks for any info JM.
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 8:36pm
I have a used Woods L59  on a C that I would sell for $800. Located in NE Ohio
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 8:40pm
  we sell more 6' [306] than 59 due to the width of tractor  no power problems either  my 2 cents
Ohio Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ohio Orange Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 8:48pm
Sunmaster is the name your looking for, they sold them under the Art's Way name also. I have one complete other that the bolts to mount it for 350 bucks . it's in central Ohio if your interested ?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 9:21pm
I just bought a used Woods 59 right hand drive for under 300.00 on Ebay. Took 150 bucks in gas and another 150 for an over night stay with vitals.  I am mounting it under a C.  Not sure I will like it under the C as the rear tires set in as far as I can get them is still wider than the mower. I might put another B together for it.
I bought a Woods L59 12 years ago for 600 bucks local and it was only in fair looking condition but held up real well over the years under a B.  That is the reason I bought the second on to keep at the farm so I don't have to haul one back and fourth with over 4 buck diesel for the big truck.
All the above said I was not and wouldn't be afraid to buy a used Woods mower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 9:44pm
Don't buy new. I have seen Woods L59 anywhere from $1150 for mine when I got it and replaced 1 set of bearings and 1 spindle. It was bent. I had less then $300 in it when I started mowing including a new Woods belt.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 9:49pm
You want an L 306 for the C. I gave away the L59 that I had and bought a new L306 I wouldn't go back. A 306 will cut to the edge of the left tires and stick oug about 8 inches past the right tire. mine was 2000 new and it was the best money I've  spent. make sure you get the optional gauge wheels and manual lift.
Bob in Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob in Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 7:10am
I have a 5ft sunmaster, I took it off my B allis, Belts big pulley, mounting brackets, & hyd. lift brackets. I put a $80.00 shaft in it. $350.00. I have a 5ft artsway on F14 that i am useing & a 6ft artsway on a CA that is for sale . Give me a call. 515-351-7151
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 7:45am
They are much harder to find used, but a Woods L503 is a really nice mower... it's basically an improved L59.  It has a spring loaded tensioner that eliminates the need to monitor the belt as closely.  I have one under my C... wish I could find another one.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 8:34am
Yes! buy used and dont pay much for it, at least around here. If the spindles are noisy they are easy and cheap to rebuild as long as you dont use Woods parts. The bearings are available at any auto parts store just ask for outer front wheel bearings for a 70 Impala. While we are on the subject does anyone remember the industrial belt number for the L59 on a B or C? I just trashed my second $115 Woods belt and I want to try one.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 9:01am
I've got an L-306 on my CA.  The deck is at least 35 years old.  Have only replaced one spindle and one guage wheel and I don't know how many sets of blades.  Butch is right about the price of Woods parts to rebuild, but you won't need to do much repair.  If you keep the belts tight and blades sharp, it is as good a mower as any new one.  Good luck.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 9:07am
Butch
You want a B225 belt. Try JayDee belts; they have them, good quality and considerably cheaper than Woods or NAPA. The website is: http://www.jdv-belts.com/catalogs.html
JM
Apoligize for hijacking your post to provide a response to Butch's inqiry. I 2nd the recommendation for a used Woods L306 for your C. I have purchased several over the years. They are very well built and can be repaired. Parts are available from Woods, or one can use more economical substitutes (like Butch suggested).
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 9:14am
Just bought a B225 belt.  $28 plus shipping.  Dayco brand.
I had a Sunmaster  Kub-Klipper on a C.  I sold the mower for $60 a ton back then.
Edited by Nathan (SD) - 03 Jun 2011 at 9:16am
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2011 at 4:46am
I bought a B222K belt from V-Belt Global Supply. They are kevlar.
This page was generated in 0.127 seconds.
