140 wt gear oil |
   rossinmich
   Joined: 12 Sep 2009 Location: West Michigan Points: 187  |
      Quote   Reply
     Topic: 140 wt gear oilPosted: 02 Jun 2011 at 4:43pm  |
Manual calls for 140 wt oil in the front pedestal on WD. That weight is no longer available, what weight is comparable?
   Jeff  Z.  NY
      Quote   Reply
     Posted: 02 Jun 2011 at 7:00pm |
   It is available everwhere.
  You will probably find it to be a 85w-140 synthetic gear oil.  |
   Jeff  Z.  NY
      Quote   Reply
     Posted: 02 Jun 2011 at 7:06pm |
   Here is a link for a straight 140 if that helps you if you can't find it in your stores.
  http://www.unifireusa.com/retail1/item.php?vn=73742&nameIT=1%20Qt%20140%20Weight%20%20Multi-Purpose%20GL-4%20Gear%20Oil&blkNO=2027-8230  |
   Jeff  Z.  NY
      Quote   Reply
     Posted: 02 Jun 2011 at 7:12pm |
   NAPA also sells a straight SAE 140w gear oil.
  Part Number: SL SL24228  |
   rossinmich
      Quote   Reply
     Posted: 02 Jun 2011 at 7:30pm |
Ok, I will try some other stores. Thanks for the info.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
