B won't start.
Mark in Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Topic: B won't start.
    Posted: 02 Jun 2011 at 10:42am
I can't get my '39 B started, crank start.  Have rebuilt mag. , newer spark plug wires, new spark plugs. All the plugs fire.  When we pull the tractor with a pickup it just back fires/won't start. There are no timing marks on the flywheel , we have looked very carefully. We have cranked to get cylinder #1 to TDC with the spark plug out and timed with mag.  It is getting gas. Suggestions???
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 1:05pm
Mark, It sounds like it is 180 degrees out of time. #1 at TDC doesn't necessarily make it timed unless you know it is on the compression stroke. Find TDC by first plugging the spark plug hole with your thumb and when you feel compression build behind your thumb, bring it the rest of the way to the top and then set it with the mag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 1:10pm
Sounds like the mag is 180 degrees off. Find compression stroke on #1. You can do it with your thumb over the hole. Once you're on compression stroke, you can use a piece of stiff wire like a coat hanger, turn the engine until the wire stops rising out of the plug hole. The timing marks are on the flywheel, they just aren't stamped very deep. From there put your mag on with the rotor pointing at #1 and the timing should be close enough to get the engine started. I can't remember if it says FIRE or just an F that you center in the window. Once you find the mark, a dab of white paint makes it easy to see.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 1:18pm
Yep! I agree with the above
Charlie
Gordy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 1:22pm
I brought home a 39 B last week same deal hand start had been parked in a pole barn for last 25 years it also will not start but it has no spark from the mag. The fly wheel has an F on it for fire #1 you can find it thru the inspection hole on left side of housing the F on mine was very faint and kind of hard to see, I put a piece of close line rope in the spark plug hole and crank it over till I can feel the piston holding the rope then start looking for the timing mark have to look close to find it.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 1:38pm
Easy no frill way without timing marks on the flywheel is to put the magneto in a vise, with plug wires installed, snap over the magneto using an adjustable wrench while holding the wire about an 1/8" away from the magneto, check for spark on all four wires. After this check hold number four wire to check for spark. When number four fires tape the impulse drive with paper tape/masking tape so it will not turn backward on you.
With your thumb on the number one plug hole turn the engine until you first feel air pressure. Install the magneto without letting the impulse turn backward with the top center of the magneto slightly off center toward you away from the engine.  Installing the magneto before the piston gets way up will save fighting with the impluse spring in getting the drive in the slot. It will not cause a problem leaving the paper tape on. When the engine reaches top dead center the impluse will fire and you will be in fair running timing. You can then move the magneto back and fourth to time it by ear.  Most of the time it will be very very close to on time with a light having the top slightly off center away from the block.
Edited by Dick L - 02 Jun 2011 at 1:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 8:05am
With the magneto (off the tractor) there is no firing order to think about. The rotor points to the terminals in order . When you have a spark ant number four terminal the next terminal to fire is number one. When bringing the number one piston up it will not want a spark to occur until it is at the very top. That is why I said (as soon as you feel pressure at the number one plug hole to stop and install the magneto. When you then continue to turn the engine over and the piston reaches the very top it will trip the impulse and the terminal that fires will be number one.
Larry B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 8:33am
i have trouble with mine. it will start if pulled 10ft. but crank all day and won't start. put new points in ,didn't help wonder if it could be the coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 9:35am
Could Be that the impulse spring is broken or the impulse pawls have the corners rounded off to where it will not catch to load up the impulse spring. (could be)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 12:38pm
Sounds like the impulse isn't working in the mag. When you turn it by hand, can you hear a loud click from the mag? Like Dick says, broken spring, pawl, rusted solid maybe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 2:09pm
how would the plugs fire if the impulse didn't work?
Charlie
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 2:26pm
Charlie, the impulse only serves the mag at cranking, after it starts, the pawls swing out of the way and it just spins. The "snap" is to generate enough current to get things moving. This is why a mag tractor with a bad impulse will pull start most of the time.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 2:31pm
Two guys asking different questions on the same thread Charlie. The impulse thing was for Larry B.
Pulling the tractor spins the magneto to where the impulse is out of the picture the same as it is when the engine is running. The rotation swings the pawls out to where they do not catch on the stop pin and load the spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 2:38pm
Yep, the impluse retards the spark so the engine doesn't kick back on the guy hand cranking. When it snaps, it spins the mag for about 20 degrees (depends on what the engine maker specified) of engine rotation the equivalent of like 300 engine rpm. Fast enough to make a spark and when timed correctly, doesn't break your arm.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 3:48pm
And I'll say it another way. The impulse gives a quick spin of the mag rotor so you can have the 3rd ingrediant in making electricity which is motion between a conductor and a magnet. This will cause current to flow in the primary windings and when the points break current will flow in the secondary windings. The impulse coupling pawl stops are set so the whole process will occurr in a retarded state for easier starting and reduced kick back. After a specified rpm is reached (almost instantaneously) during start centrifical forces keep the pawls away from the stops and return the mag to a preset timing. On some very well tuned engines it is possible to make it idle down far enough to cycle on the impulse. I wouldn't recommend it though as its bound to not be good on the impulse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 4:49pm
So guys when timing the mag with the engine it is best NOT to pull the tractor to start it, but just crank it?? Thanks for ALL your help, I appreciate it.
redwhisper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redwhisper Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 5:45pm
Will this method of timing the magneto work on a WD45?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2011 at 6:32pm
Yes!
