problem! on the wc
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Topic: problem! on the wc
    Posted: 29 May 2011 at 9:11pm
today at my local show my 38 wc started blowing out white smoke.. what could that be? is it bad? it rained the day b 4. i worked it hard on a fan. its the hardest its ever been worked.. could that be why?
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 9:33pm
How long has it been since its been really worked? Did you check your coolant and oil levels and see if you have mixing? If it hasnt been worked for a long time and had a weak head or head gasket, that could be your issue.....first things I'd have checked.....when it rained did you have something covering the stack?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 9:35pm
the stack was coverd but there could have been som water get in around the pipe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 9:36pm
its also a rebuilt engine done not to long ago
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 9:40pm
White smoke is water. I would guess the head gasket let go. Check oil level and water level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 9:42pm
oil is good but idk about water... i hope its not the head gasket.. it quit for a while wile i was driving down the road i think it might of been water. ill find out when i start it next
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 11:52pm
A head gasket isn't that hard to replace. The only thing is making sure you get it on there right (I had to replace it twice).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 6:58am
Did you retorque the head after you put it together and ran it up to temp once? You might give that a try. After warming my diesel 262 up once and allowing it to cool overnight, it probably lost 1/3 of the torque spec. I cranked it back down to spec and after maybe 8 hours of run time, dry as a bone.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 7:19am
Head gasket  would be my first gess specially if it smokes after starting for a time then clears up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 7:20am
i didnt rebuild it. it was like that when i bout it in the fall and he said that he rebuilt it a couple months before that.
This page was generated in 0.207 seconds.
