Deutz-Allis 385
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: Deutz-Allis 385
    Posted: 13 May 2011 at 8:13pm
I have heard nothing but great comments on this planter. Some say it is still one of the best planters ever made!! Was this Allis Chalmers technology that was gunna be a orange planter or was this something Deutz had going on?? Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 9:03pm
It is the old AC design. I have a 8 row and like it. Parts are the draw back.  MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 1:39pm
We ran the prototype - orange - had 78 and 74 units inbetween.  Dave Murray _ still with Agco- was the project engineer.  Unit had some problems early on - mostly scrapers not heavy enough in sticky mud.  First openers wore out too quick and were thickened on leading edge. Landoll came out with a cast aluminum hopper bottom that was almost a necessity.  Unit needed a White air system to be nearly perfect.  Later units also had alternate leading edge coulters  to prevent side draft.  Problem with unit was AC had 80% market share in no-til market which was only 20% of the total market. Lou Swoverland was the head of planters - drove him nuts when they (Deutz) woild not give him a frame to go after the 15" row double crop market - instead they went after the 80% of the market they had NO market share in.  Miserable failure - sold the planter to Landoll and went with White.  The lack of a narrow transport narrow row planter plagued  both planters till recently - White has a central fill unit .  May the Quadradisc RIP. Len Schriver wrot the marketing specs for the QD unit BTW - you should have heard him chew on the DA guys.
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 2:35pm
Just bought one a couple weeks ago. Planted about 15 acres in last years soybean stubble with out a problem, Planted 12 acres in last years corn and it never missed a beat. Only sprayed with round-up / 2-4 D, thought I would see how this no till realy works. Next time I will knock down corn with a disk because it was hard to see the marker lines very well.
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 8:04pm
Thanks for the inside scoup tbran!! I hear nothing but great things about the 385. I wonder about repair parts?? Ryan
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 8:05pm
David, once you are on an established row pattern, just leave the stalks standing so you can plant between the rows (less residue in your way).  Then leave the markers up and use the old rows as your guide mark.  That's the way people here without GPS do it.
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 8:09pm
Never did ask the model number of the planter I was helping Jim rob parts off of out in the rain today but it was a green DA planter.  Was mostly picked over but there was a few good parts left on it yet.  Jim thought it was a low houred planter.
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
