agco 8610 won't start
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Topic: agco 8610 won't start
    Posted: 13 May 2011 at 8:48am
have an 8610 in the shop, just split for broken bell housing bolts. Tractor won't start on it's own. will start when electronic governor is overrided in the governor cover. We have four flashes on the right side cab piller throttle control panel. anyone know off hand what the four flashes mean.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 1:15pm
Been a while since I worked on one of those,so I don't remember what the foor flash code means without looking in the service manual.That tractor has a sensor that screws into the bell housing at the top side. It senses the engine rotation from the flywheel teeth I believe.It has to be good and the clearance correct for the tractor to start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 2:39pm
it was the magnetic pickup on the flywheel, machine shop pulled it out to weld on the bell housing, then put it back in with no regard for where it was set. when the tech tried to start the tractor the flywheel grenaded the sensor.
