D 19 wheel removal-new way |
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2083 |
Topic: D 19 wheel removal-new wayPosted: 30 Apr 2011 at 5:36pm |
While going thru the D 19 diesel that I got a couple months ago...one of the problems I encountered was being able to move the back wheels. I have the specialty bolts to remove the wheel bushing (or really push the wheel center away from the wheel bushing) but a previous owner must have damaged the threads in the wheel center. To overcome this he re tapped the wheel center to a 3/4 size and drilled out the wheel bushing so the 3/4 bolt would go thru it. This made my removal bolts worthless. We tries the usual things but no good. I then got the idea that I could use our skid loader with hydraulic jackhammer to "tap" the wheel center loose from the wheel bushing. The jackhammer is equal to something like a 300 pound sledge hammer. The point on our jackhammer is dulled to about the size of a baseball so is pretty blunt. Well we did it today, picked up the rear of the D 19 with a forklift, removed the three holding bolts and "tapped" the wheel center loose from the wheel bushing. Took about 2 seconds. Of course not we had to change the sheel center to get back to original but at least the worst was over with what I call my really, really, really big f___hammer.
By the way, I am lucky enough to be in a business that has a skid steer and jack hammer but if needed...there are a lot of these around and if a guy needed to do the same as I did...I would think that you could get your local contractor with the same equipment to stop by and tap yours off for you for a reasonable fee. Den |
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1010 |
Posted: 30 Apr 2011 at 5:50pm |
Den, where did you put the j-hammer on, the wheel, or the axle? Sounds like a better option than beating on them with a BIG hammer for half a day. ( been there done that )
Posted: 30 Apr 2011 at 6:02pm |
I put it on the wheel center. Moved it right over. Den
Burgie
Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Posted: 30 Apr 2011 at 6:58pm |
Hey Den, No such thing as overkill.
"Burgie"
Posted: 30 Apr 2011 at 7:37pm |
You're right there Burgie! The first side took a little time as we had to change the center out to get it back to the original set up. The second side took 20 minutes to jack up, knock loose, clean all the mating surfaces, anti seize the H--- out of all the surfaces and re bolt and drive off. Nothing like "more power" to make things easy. Den
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 01 May 2011 at 6:51am |
Great thinking. How's it go......necessity is the mother of innovation. I just made a mental note. I hope I don't forget where the note is the next time I have trouble moving wheels.
Wink I am a Russian Bot |
Dave in il
Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
Posted: 01 May 2011 at 10:06am |
I know I never have the camera around when I do something like that, but I would have loved to seen a few pictures. LOL |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8763 |
Posted: 01 May 2011 at 12:13pm |
interesting concept, Darrel
Posted: 25 May 2011 at 9:19pm |
Bring it back from the past, this is the way I got mine to move. Den
