New Holland Manure spreader beater teeth
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: New Holland Manure spreader beater teeth
    Posted: 25 Apr 2011 at 8:52pm
I am going to need some new teeth for the beaters on my NH manure spreader. This is an older spreader, I think the Model is a 140. The old teeth are riveted on the bars...I think I can grind them off and bolt on new ones if I can find them.  There are two teeth to each piece. Spread manure for the school garden today and I think someone sold us a bunch of rocks covered with crap......
ALLIS EXPRESS!
This year:
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 10:16pm
At lest you didn't run a cement block through yours. I did that once through my AC140. It chopped up the block and didn't even bend a tooth. We have a lot of stone around here, and I often load 1 or 2 in a load.
You might find other brands of theeh are the same. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 10:29pm
Well a cement block would have been a piece of cake compared to a couple of the boulders I had to lift out of the spreader.  I used the D17d to pull the spreader since I thought it was rock free.....but after seeing the rocks fly, I decided to pull up my hoodie and then my Carhart hood...and then hold my hand on the back of my head just in case. I never got nailed, but didn't look back too often either.  One rock shook the steering wheel pretty good when it hit.  Soooo I didn't see a couple of the big guys till the damage was done.  One was so big I had to get it on my knee before I could flip it out of the spreader, I'd guess 150#. Nothin like climbing into a slimey smelly spreader and lifting out slimey smelly rocks. Needless to say, I wasn't too happy with the situation, especially since it was volunteer work....and that manure spreader is my livelyhood.
ALLIS EXPRESS!
This year:
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 10:47pm
will the teeth outta an old harrow work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 10:56pm
If you can picture a flat piece of iron about 8" long, an inch wide and 1/8" thick -  cut the ends  to a point about 2" long x 30 degree angle, bend up each end 90 degrees so you have a U shaped piece.  This is riveted onto the beater bar. A lot of them are bent over, but when you try to bend them back they snap off....obviously heat treated for strength.
ALLIS EXPRESS!
This year:
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 12:23am
Doesn't the whole bar full of teeth unbolt from the beater assembly? I made whole new bars for a JD model N once. Took 1 1/4 inch steel square tubing the width of the old bar assemblies. Drilled holes all the way through 5/8 round. Welded in 5/8 rebars sticking up about the height of the old teeth.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 5:00am
I have some NH & NI parts spreaders, there should be some good ones there. I will look when the sun comes up.  It will be a few days befroe I can get them, a littie wet out there. Richard
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 7:01am
New Holland used to sell new teeth and also new bars.
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 4:20pm
I'd appreciate that Richard.....we are a little wet out here too, it has been raining non-stop for 24 hours now.  My yard is a lake....crazy weather!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 4:25pm
oh...kinda like stalk shredder knives?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 8:31pm
Oops it is a model 510....guess I had AC numbers in my head last night!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 8:36pm
Here is a pic compliments of Richard A, my spreader is still at the school garden.
Edited by Eldon (WA) - 26 Apr 2011 at 8:37pm
ALLIS EXPRESS!
This year:
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 9:00pm
Look the same as New Idea Spreaders used also.
Hurst
1979 Allis Chalmers 7000
5800 Hours
This page was generated in 0.217 seconds.
