1945 Allis Chalmers(WD45)
oilman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oilman Quote  Post ReplyReply Direct Link To This Post Topic: 1945 Allis Chalmers(WD45)
    Posted: 21 Apr 2011 at 11:25am
 I have a lady that has 5 of these and she wants me to change the oil in them.The current oil filters are white and don't have a number on them.Anyone know the oil filter number for this tractor.Also,is it hard to change the oil in one of these tractors.Thanks.
WD in kansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in kansas Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 11:58am
It's super easy to change the oil, but they are not 1945. Maybe 1954? The filter you want is Fram C159
1950 WD, Duetz Allis 613
Mark J. N.Y. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark J. N.Y. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 12:12pm
Baldwin filter no.T-300m
Post Options Post Options   Thanks (0) Thanks(0)   Quote oilman Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 12:17pm
Thanks for the replies.So,to change the oil,just drain from pan and replace the filter?Noticed the filter is standing upright,anything special to do there.Also,what type of oil.She said just a SAE30.Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in kansas Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 12:22pm
Thats pretty much it. There is an oil tube running up inside the filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 12:25pm
The only thing "special" to do is make SURE the tube attached to the filter housing stays in the housing and doesn't come out with the filter. That little tube is vital to the lube system on these tractors. The new filter will slide down over the tube before screwing it on.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 12:48pm
Wix 57011 is a good filter also.
bluebanshee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bluebanshee Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 5:50pm
Hasting Premium is LF405. $13.33 locally...
Edited by bluebanshee - 21 Apr 2011 at 5:51pm
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 6:05pm
Oilman, You may know this, but I always warm up an engine before I drain the old oil. This helps remove contaminants that settle out while sitting, especially with nondetergent oil. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 3:21pm
make sure you use a non-detergent oil, and when putting on new filter push filter straight down over the tube down don't turn or twist it till it hits the threads..
This page was generated in 0.172 seconds.
