Making a belly mount blade for WD
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: Making a belly mount blade for WD
    Posted: 20 Apr 2011 at 11:28am
Has anyone here made or seen a good one?  My rear mount is just too crude to do a good job of grading my gravel driveway. (front of tractor goes up -- blade digs in gravel, etc).  I thought about trying to make one from the front part of a cultivator (but don't have a cultivator, ha) Pictures or links would be helpful.......tx
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 12:45pm
Mr. Double "O", think about bolting a pair of wheels behind your rear mount blade.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 4:19pm
I have one that I built for my C you could build a similar on for a WD.
If you look on your final drived there are bolt holse fwd and aft of the Axle nut Cap. that is where the drop brackets for the #3 mower attach. just run push braces fwd from there. make sure you put a swivle in one side. I welded at  fixed angle and used pulleys and cabled to lift. I only used a section of grader blade cutting edge for the blade. I'll try to get photos when the weather lets up. we had 2 " of snow today.
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 5:31pm
I have wanted to do the same thing on my wd45.  That would be great for blading the driveway.  I know that I'll never get it built because I retired last year and now I will not have time.LOL
Dennis
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 7:11pm
One of these days I'm going to make one for my G. I know how I'm going to do it, just haven't done it yet.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 7:45pm
Here are pictures of the One on My C
and the drop brackets on WD45
The blade works very well for grading the road. I've also used to shape fill in pole buildings.
LloydCentWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LloydCentWi Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 7:46pm
The G would make a great grading tractor.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 8:23pm
I paid a Buck  2. 98 for this Maintainer,I do have a ol'  W- patrol to grade if i need to .
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 8:55pm
Fred cheats...  ;-)  He BUYS 'em 'factory built'...
Edited by DaveKamp - 20 Apr 2011 at 9:09pm
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 8:57pm
 what is ur profile pic a 45 with a roll over cage or what can u post a  pic of it i wana see it
lol maybe my color is fixed now lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 11:02pm
Dave Richards: I made a setup w/wheels, but it's difficult to get adjusted and difficult to make changes.  Had a belly blade on a F**m**l cub once......it worked great........but got rid of the cub.
Dakota Dave: Tks for photos.  Looks simple enough (much simpler than trying to hang one from cultivator arms).  I'll have to figure out a way to raise/lower it.
Fred: Tks for photo.  May incorporate some of that design into whatever I end up building.  If I had that rig, would have to park truck outside and put grader inside. ha ha
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 11:30pm
ACD21man: It's just a brush guard to keep me from getting knocked off tractor while brush hogging. Made from 1-1/4" and 3/4" sch 40 pipe.
Edited by Osage_Orange - 20 Apr 2011 at 11:32pm
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 7:09am
Several years ago I added about 5ft. to the frame of a WD, then made a 10ft. grader blade that hyd. angles to a 45* angle both ways. The hyd pump on the WD is low volume and works great. It also has a wide front.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 8:32am
I would like to have one of these behind my 170 but cannot justify the price.
http://www.hoelscherinc.com/prod_grgrader.htm
pa steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pa steve Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 11:08pm
I BOUGHT A C THAT HAD A WOODS BELLY MOUNT MOWER ON IT.
THE GUY SAID HE HAD A BLADE THAT WENT WITH TRACTOR.
SO INTO THE WEEDS WE WENT TO FIND THE BLADE.
HERE IT WAS A WOODS BLADE (LIKE NEW)THAT FIT ON THE BRACKETS THAT THE MOWER USED.WORKS GREAT PLOWING SNOW AND GRADING MY LANE
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 8:18am
I have one I built for a G I'd sell. Works and looks good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 9:11am
Ken, I think I can build one cheeper than I can drive to WI. and buy yours. But I'd like to see a picture of yours.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 9:52am
I'll try this for posting a photo of my belly mount blade I made for my G. Hope it works! This process is not intuitive to me.
http://www.allischalmers.com/new/forum/file_manager.asp?UL=true&FN=Picture1.jpg
