inline fuel filter, how close is too close?
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: inline fuel filter, how close is too close?
    Posted: 20 Apr 2011 at 11:10am
Have a WD with the picker side panels on it.
Thinking of putting an inline fuel filter on the gas line, and wondered if I should be concerned if the filter gets too close to the engine block? Should I stay away from the block or not worry about it?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 11:42am
I would not put on an inline filter. that is what a sediment bowl does. Some times you will have fuel starvation with an extra inline filter.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 1:19pm
The common inline filters are for use with a fuel pump, not gravity and can cause fuel starvation in a gravity feed system. The few rated for gravity often aren't rated for enough flow for a tractor ending. I think best left out.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 4:29pm
I have to agree, leave the filter in the auto parts store and clean your sediment bowl regularly.
Burnt Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burnt Orange Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 5:19pm
Napa carrys a gravity fed fuel filter for tractors.Works just fine.Lots of fuel flow have been useing them for years.Brian
tomdavison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomdavison Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 6:30pm
I have in line filters on all of my tractors (B,C&WC) and have never had a problem with fuel flow.  When I farmed with our C, many time I had to drain the gas from the carb and clean the sediment bowl.
  The in line filter filters much better than a sediment bowl.  A sediment bowl will not filter out all of the dirt, water, etc.
Boomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boomer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 6:56pm
I agree that they are inline filters are not rated for gravity feed. However, I have installed an inline filters in most of my tractors. I have kept the original sediment bowl to keep the large chunks, but more importantly as a water seperator. My inline filters were purchased from O'Reilly and are the glass type with replaceable elements. The replaceable elements I get from another auto supply store because they are cheaper. Tractors have that have the same filter installed are a 1920 Agco, WD45, CA, WC. Rubber gas line running on the outside of the air filter canister. Installed where the filter is between the carberator and air filters. Most of my carberators have been rebuilt by B&B, and don't want junk getting into those carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 6:59pm
Attach it right to the sediment bowl or very close to it.
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 7:10pm
Don  use a metal filter not a plastic one I put  mine by the carb.  2 or 3 " back from the end of the fuel line.     Kent.       ( did you get the Maple season pictures )
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 7:16pm
Putting an inline filter on the D12 has really saved our butt.  My zero turn came with one and that is gravity feed.  Can never have to much protection.  Sounds to me like the purest think that 1940's technology is the best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 7:33pm
After I fabbed up a new metal line on my CA, I haven't had a carburetor problem in 15 years. Only has the sediment bowl...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 8:46pm
Thanks guys, probably go with one for now. I don't have a screen in the sed. bowl.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 9:07pm
Clean your tank and use clean gas and you will be fine with just the sediment bowl.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 9:14pm
I like the filters to be the lowest point in the line. If any water gets past the bowl the filter will catch it then. I work alot of road ditches. Sediment bowl works good on the flat. I had too much trouble with fine rust getting past the screen in sediment bowl.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 9:38pm
  Hello Don   If you are going to go through all that work,  I would put a fine mesh screen into the TOP of the sediment bowl  "should look like a cigarette with the top bent"  that will stop any crud from getting into the top of the sediment assy.  Allen
This page was generated in 0.336 seconds.
