B fuel Level Check |
Post Reply ![]() |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Apr 2011 at 1:02pm |
So what is the tried and true method for seeing how much gas is in the tank for the B/C/CA?
Can't see in clearly enough to eyeball it. Need a long dowel or something and mark it.
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
Brian Jasper co. Ia ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Yep, old fashioned stick gauge...
WD in kansas ![]() Silver Level ![]() ![]() Joined: 28 Sep 2009 Location: Spring Hill, KS Points: 164 |
That's what I do on my WD. I have a special stick in the shop. No marks on it, I just know how full it needs to be to mow the place.
1950 WD, Duetz Allis 613
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
A piece of old yard stick tucks in between the seat cushion and frame on my B. An inch in the bottom goes way further than an inch in my 45. :)
Ron Eggen ![]() Orange Level ![]() Joined: 15 Sep 2009 Location: Lohman, Missour Points: 548 |
We always used the power shift wheels wrench handle on my grandfather's WD, but I realize that a B doesn't have one, so any dowel or like item would work.
JohnCinMd ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Westminster, Md Points: 1438 |
The toolbox on my WD is just long enough to fit the gas guage (dowel), in.
George Davenport ![]() Silver Level ![]() ![]() Joined: 20 Sep 2009 Location: Trenton NC Points: 127 |
I used a 14" wooden paint stirrer with a hole drilled in the top. Painted it with 2 coats of clear urethane and made notches and lines at each gallon. The first gallon is approx 1 1/2 inches up and each gallon thereafter is 1 inch higher and top is 11 inches (full). You can also paint one with a flat paint and is more visable.
Greg (Hillsboro, OH) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Hillsboro, OH Points: 1188 |
My B is a crank start, so the crank makes a wonderful gas guage. |
Chris/CT ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Just keep plenty of fuel in, easy.
bikley ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Maryland Points: 5406 |
you never have to much gas the way i figure
Auntwayne ![]() Orange Level ![]() Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
We have 2 yard sticks hanging on the wall, use them on all of our tractors, except the "new" one !!!
morton(pa) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lancaster, PA Points: 1234 |
I used a dowl rod cut down so it was about 3 to 4 inches above the tank. I then stored it along the steering column where the hand crank goes. Works well! Just make sure you put it back where its "made to go" instead of sitting it next to you on the seat! I had one decide that it wanted to taste dirt and it got ran over by the tire. It was a lot cheaper to replace then any part you get from AGCO though!!! LOL
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3914 |
Stick hangin' on the shop wall by the door. Same "gas gauge' for all the tractors in the shed!!
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
There's an old Army Aviator saying that says,"The only time you have too much fuel is when you are on fire."
wbecker ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: STL Points: 837 |
Standard paint stir fits in the B tool box.
Tedin NE-OH ![]() Silver Level ![]() Joined: 30 Mar 2011 Location: OH Points: 177 |
Any thing except steel, don't want any sparks.
Post Reply ![]() |
