Will a D17 Gas Handle a 4 - 14" Plow?
rhartwick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhartwick Quote  Post ReplyReply Direct Link To This Post Topic: Will a D17 Gas Handle a 4 - 14" Plow?
    Posted: 18 Apr 2011 at 9:29am
This is a bit of a loaded question, but I found a nice 4-14 semi-mounted AC plow near us.  I know the D17 IV will walk away with a 3 bottom under most conditions.  I wonder if it would handle a 4 bottom, 14 inch set?  The ground it will be plowing is fairly heavy soil, typical of central NY, with some rocks.  The land would be moderately hilly but not extreme.  I don't know the model # of the plow, but it is 3 point with spring breakaways, with a trail wheel and hydraulic lift.
It seems like these might be a little too much plow for the D17, but was wondering if anyone has experience with similar sized plows on this type of ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:31am
D17 was designed to pull 4. A wd45 will pull 4 in most conditions.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:44am
I have pulled a 4 bottom semi mounted with my D17 IV. No real problems other than it will use a lot of gas.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 10:10am
We had an early '58 D17D with a fully-mounted 4-14
not a problem even in alfalfa
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 10:13am
Dad worked for a guy that pulled 4-16's in heavy soil with clay noles.  Had a dual on the land side and pulled in it 3rd low.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 5:39pm
I sure hope it does because I bought a 5 btm semi mount AC for a D17 Diesel, or the gas, and Im screwed if you cant pull 4!!!!!!However my friends brother in law pulled 5 with his 17 gas for years till he bought a 190
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 6:26pm
Depends on the soil, but mine plays with a 4 - 14 snap coupler most of the time.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 7:59pm
  we pulled 4--16.s with a d-17d  no problems with duals on land wheel 80series semi mt
   2nd  hi side  let her smoke  heavy soil northern ind. clay soils
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 8:12pm
We plowed with a couple D-17's back on our farm when I was younger.We pulled a 4 btm 16" snap coupler plow and some 3 btm SC plows.Our 59 D-17 pulled the 4 btm. a lot better than the 63 D-17 for some reason.Soil,tires,weight and speed all come into play.I am sure any D-17 will pull a 4 btm ,how fast is the question.
