Is this crack a problem
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Is this crack a problem
    Posted: 17 Apr 2011 at 9:36am
The crack between the cylinders I have seen before but it extends through the very top 1/8 inch of the sleeve also. It is just in the very top beveled 1/8th of the sleeve. Will it leak here? Can it be shut with a mig or tig in place? Leave it? Replace the sleeve? The piston and the rings stop well below this. Thanks for the info ahead of time. Dana
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 9:44am
Looks to me like it would eventually leak. But if you put a new sleeve in it what is there to say it won't crack again. If it was mine I would take a serious look at the block.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 9:44am
crack in block OK. sleeve is no good. Very hard cast iron . You can't fix it. Need new sleeve.  Dave.
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 12:34pm
Is this the 190 series tractor you showed us about a month or two ago?
Danny Raddatz
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 1:16pm
Block okay! Sleeve shot and not usable.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 1:35pm
depends on if it's ina tractor...or an airplane!
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 1:57pm
both sleeves in the picture look cracked to me and cracks in sleeves grow with heat.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 2:22pm
I think what I'm seein' (the LH sleeve cracked at 12:00) is what ML is seeing... check-see if that sleeve is cracked too.
The fracture in the deck isn't a big deal, apparently it was nature of the beast, and the seal between sleeves and head is still intact and fine... BUT... my WD's block had been frozen and repaired, and the webbing down below is cracked, so no matter what I do with sleeves, they won't seal on account of the block 'opening' up and leaving a gap around the sleeves.  if your webbing (down below the deck) is still intact, I'd say stuff in a new pair of sleeves, pistons, and rings and fire it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 2:41pm
Nope guys only the 1 sleeve has the crack. This is the D15 II.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 3:46pm
definately needs one sleeve and the other decked then . what caused the indention in the second sleeve?
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 3:54pm
D15 II has very thin sleeves anyway so it makes all the more reason to change it, you don't want to trash the rest of the engine trying to take a shortcut. 160 CI engines are expensive to fix as it is, I certainly would not tempt fate and end up doing the job over again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 4:59pm
ML what does decked mean? I see that mark and next time I go over to where the tractor is I will check it out. I remember seeing some mark there but it was I think smooth and a non issue but I will check. Thanks, Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 5:06pm
He means having the head gasket surface of the block machined so it's flat. Cracks between the tops of the sleeves will be sealed by the head gasket. Obvious the one sleeve is cracked and no good. The pits in the other one make it unuseable too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 6:12pm
Brian covered it but I will respond to . Your asking the steel fire ring in the gasket to do allot when you have gouges pits or cracks in the sleeves top flange that the gaskets fire ring sets on.  the steel ring in the gasket needs to be on a flat surface to bite into or compression will go right under it through the pits gouges etc.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 6:16pm
So if you "Deck" the block, would't you need to take the same amount off the top of all the sleeves?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 6:17pm
yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 7:52pm
You can take it from the sleeves, or recut the counter bores the sleeve flanges sit in. I'd be more inclined to cut the bores to insure the sleeves set perfectly perpendicular to the crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 8:04pm
It doesn't look as though the deck or sleeves have been cleaned up so I wonder if the black on the sleeve to the left has a flaw or has some kind of fly crap on it.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 9:36pm
simple, just say no to crack!! LOL.   Darrel
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 9:42pm
if you have ever o hauled a 230 buda in a 45d,out of 10 blocks,9 will have inter cylinder web cracks.no big deal,if the sleeve is cracked...replace it.the head gasket will seal the web crack...
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 9:44am
Thanks y'all, I just gor back from a 3 day trip and will check out that cyl #3. I am thinking its fine and just some picture reflection thing going on. Will report asap. Dana
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 1:49pm
160 parts are spendy, if your interested I have a set of used sleeves out of a 160, I could fix you up with a couple.  I put a new set of sleeves and pistons in an Industrial 60 a year ago last winter, I dont throw nothin away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 5:34pm
Thanks Skip. I need your tele number anyways. My e mail is captaindana@msn.com if ya wanna shoot me an e mail. I am not sure what I am going to do with her yet until I get to the underside interior. Dana
walters444 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote walters444 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 7:37pm
call me " mike"   if im not avail ask for ron  we will steer you in the right direction and if needed solve your prob. thanks   remember if you have  block problems its very possible you also have a head issue might want to check  217-472-3333
Edited by walters444 - 20 Apr 2011 at 7:38pm
