D17 vsD19 diesel engines
Roger Nolin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Topic: D17 vsD19 diesel engines
    Posted: 09 Apr 2011 at 9:14pm
is there any difference in the D17 262 diesel and the D19 262 diesel engine other than the turbo on the D19? thanks < id="gwProxy" ="">< ="ifofjsCall==''jsCall;elsesetTimeout'jsCall',500;" id="jsProxy" ="">
Larry B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 9:24pm
i have had both and i don't think there is any difference other than the turbo.do you still; have the wc i sold you2 or 3 years ago?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 9:30pm
yes, I do. it has been joined by a 1935 U, 1950 WD, 1954 WD45, and I "sold "Dads 1967 190XT diesel to my youngest son. Not enough money to play with all of them. < id="gwProxy" ="">< ="ifofjsCall==''jsCall;elsesetTimeout'jsCall',500;" id="jsProxy" ="">
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 9:31pm
Larry, I think it was lots longer than 2-3 years, it was the first time the WHO ride was in Spencer. closer to 10 years I think< id="gwProxy" ="">< ="ifofjsCall==''jsCall;elsesetTimeout'jsCall',500;" id="jsProxy" ="">
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 9:36pm
I always thought the D19TD started harder because they had lower compression due to the turbo.....D17 15.7:1, early D19 14:1, late D19 15:1
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 10:02pm
I think the pump is different too, and maybe the injectors.  Also I think the D19's all have block mounted water pumps.
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 10:46pm
I may be wrong but I believe blocks are same but heads are different , friend once tried to repair 19 with a 17 engine and when he put it back together I wouldn't run right with turbo untill he put 19 head back on the 17 block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 10:51pm
There were 4, if I remember correctly, cam choices for the D262 engine. The early 262 in my D17 had the same cam as used in the wd45 diesel. This was according to Valu-Bilt where I got my reground cam.
I'm pretty sure all D19's had the water pump on the block. I did notice that my original block did not have the hole for the turbo drain back. That could be only on the block mounted water pump blocks though...
Edited by Brian Jasper co. Ia - 09 Apr 2011 at 10:54pm
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 6:37am
My repair book shows the earliest D-19 had head mounted pumps and differant cams ,pistons,valves. Also series III and up had block mounted water pumps too. I was always told that the block mounted pumps cooled better.
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 7:36am
Brian-Question about what I am doing on my D19 D262 Diesel Engine.  I am using a reground D17 D262 cam (1958 vintage) in my D262T.  The blasted parts book shows both cams as being identical part numbers...74516085.
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 5:13pm
You can not use a early cam in a latter 262 unless you change pistons because they are higher lifted cams and the valves will hit the piston. That is why earlier pistons have a recess on them. Also the valves are slightly smaller too on the later 262 and 262T. This is stated in the D-19 repair manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 5:29pm
Brian, you cannot use a WD45 cam in a D17 or D19 because the rods will hit the cam.  There has to be flats on the cam where the rod passes on it's way around
