planter monitor
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: planter monitor
    Posted: 06 Apr 2011 at 10:26pm
I've got an 8 row 36 AC planter, model 600 with #78 row units on it, and the seed monitor only works on about 3 of the 8 rows. Was going to upgrade to a different planter this year, but looks like that won't happen, so I'd better do something to get a working monitor. I think to just go to an aftermarket one would maybe be my best option. I did see an ad one time for a company that made a monitor that was supposed to be compatible with anyones seed sensors, but I now have no idea of what the name of that company is. Anyone have any suggestions for me? I'm thinking that my problems are some in the monitor, some in the wiring harness, and some in the sensors, so starting from scratch may be a good option. Thanks, Darrel
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 10:33pm
There's a guy on here from MN called monitor doc. May want to try to get it fixed?
HD16,917H,185,7050,8030FWA,8050FWA
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 6:00am
Well,  the first thing I would do, being an electronics guy, is find out where the problem really is.  I would hate for you to send the monitor in, only to find out the problem is in the wiring harness or the seed tubes.  The best troubleshooting I can think of is to remove the seed tube of a good row, and take it to the row that is dead, and then drop a few kernals down the tube.  Most of these should have quick connectors at the row unit, making this a fairly easy step.  I bet you will find your monitor really does work, and you have a few dead tubes, or you will in the above process find a few bad connections as well.  The other quick thing to do is veryfy that your harness doesn't have any nicks, pinched points, or broken insulation anywhere, as this will be a sure sign of internal wire damage.
Hope this helps.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 6:36am
Been a very long time since I worked on one of those units. First, when you first turn the monitor on, I think all 8 lights should light up for a couples seconds....this is checking to be sure all the bulbs are OK....replace burned out bulbs as needed. Second, if the connection between the monitor and the planter is that rectanguler plug with flat spades, take a needle nose pliers and put a slight "twist" on each male tang.....then spray the female and male plugs with WD40 oil and assemble them together....then see what you got. I've fixed many back in the day just because of poor contact at the plug.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 6:59am
Use some emory cloth on those connections, check to see that your monitor is connected to the BATTERY, not somewhere else, fixed many of units this way. It you have a 12 pin connector and you do need a consel, i have one i could sell. Good luck, those 12 pin connections need to be shiney clean. Randy
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 7:05am
I have done basically the same as OB when working on planters, and just take a wire from a bad row and move it to a row unit that works and see if that makes that row light up when you drop some seeds down the tube.  Just be sure to label which wire goes with which row before you start switching them, and 99% of the time I find the sensors are bad and nothing wrong with the monitor.
Jim in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim in MO Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 7:06am
call sensor one they are in KS. 1-800-736=7671. Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 7:41am
thanks for help, guys. I'm pretty sure that a new wiring harness would be necessary to make the ole thing work,as it is in terrible shape, and I have my serious doubts that one is available any more, so that is kind of the reason that I thought maybe just upgrade the whole thing. The monitor was supposed to have been gone through not too long ago, before I bought the planter a year ago, so maybe there is hope for it. As for the sensors, they are slightly spendy, but I guess cheaper than the skip row plan I had last year! Darrel
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 7:53am
I got 2 12 row monitors on ebay for $36. The guy must have kept them in his sock drawer to be in that good of shape.
Sensors and wiring harness cause way more problems than console, in my experience.
It isn't too hard to make a planter half of the wiring harness. Each row has a common and a power wire and a signal wire. Main thing is to make sure wires can't catch in anything. No matter how windy it is.
Edited by E7018 - 07 Apr 2011 at 7:57am
Wade (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wade (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 7:56am
Does anyone have a good source for replacement sensors for the "78" units?
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 9:53pm
Just re-using this thread here...  our planter monitor is no help at all.  It will blink some, but thats it.  So- I have checked it out.  (this is on a 4 row #77 air champ by the way) Ran a jumper wire on the monitor side of the 10pin connector from the power out to a signal port back to monitor and every light lights up when plugged in then removed from its individual plug.  I then made some jumpers to hook from the monitor's 10 pin plug directly to the sensors.  I have 2 that light up but dont' seem to send a signal, and 2 that dont light up and also dont send a signal.  So, I'm thinking its the sensors themselves, as I plugged back up to the harness (as if I were running in the field)  and got the same thing.  I've cleaned the 10 pin plug, both monitor and planter side.  but haven't found a way to clean the 3 sensor plugs.  I'm leaning toward the sensors being bad.  but all 4?? Thanks for any more help/information.   -Wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 10:12pm
Wes, on mine I've come to the conclusion that my wiring and my sensors are bad, cause I tested my monitor on the advice of the "monitor doc" from this site, and it should be good. I ordered new sensors and a whole new harness from sensor 1, and I'm hoping for the best. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 11:19pm
Darrel, how did he say to check the monitor..by using a jumper wire like I did?  or some other way?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 12:39am
i quit using my 8-row monitor, as it started doing what darrel's was doing...had the box checked and it was o-k, started doing the sensors, they were o-k, started tracing wires, and they are tiny things...the monitor guy says never splice those wires. soooo. i just checked the planting every round for a day or two, and all was working...never used it again, never needed too! darrel when you decide to sell that planter let me know!
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 12:02pm
You guys need the sensor test box.  I have one, it worked.  Saved a lot of guess work.  I dont want to sell it, but be on the lookout for one.
This page was generated in 0.073 seconds.
