Another piston ring question
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Another piston ring question
    Posted: 06 Apr 2011 at 6:54pm
Why, on some sites, they want you to fill in the 4 different piston ring thicknesses? Like how do you determine this? Sorry...this engine rebuilding is new to me and I find it very fascinating! Dana
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 6:59pm
I don't think Hastings needs you to provide all that info, call them they will ship em' right to you, Find out from engine guy's if you should get chrome or regular, chrome rings take longer to seat from what I hear.
Edited by Chris/CT - 06 Apr 2011 at 7:00pm
48AC/WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48AC/WD Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 7:01pm
Because you have compression rings on the top and an oiling ring on the bottom, in the automotive industry there is only 2 top rings and 1 lower ring (3 total), a tractor has (4 total) AND because all ring lands and thicknesses differ by thousandths per manufacturer, hence why in the automovive industry you replace pistons and rings in pairs of matched sets.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 7:39pm
 After you have cleaned the ring grooves , get your feeler gauges & measure so you get the proper rings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 4:57am
OK thanks guys. So Gary, measuring the groove for ring thickness, how tight should it be? Not knowing anything lol if I measure the groocce at 1/8 inch what ring size would you order?
davefullmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 5:31am
I have found over the years that if I find the oldest clerk in the parts store to help me,  I can get pretty good answers to my questions like this.  Some of these guys have a lot of knowledge tucked away in their heads that are really helpful.  If I ever have any oddball situations or questions,  the old guys seem to be able to answer them because sometime in the past, they have worked with someone else with the same problem.
Sometimes the young ones just aren't willing to put in the effort to help.  My parts store people are some of my best information.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 8:12am
Actually you will only need to fill in that you need  three 1/8" compression ring and one  3/16 oil ring. You will have no other choice for that tractor using Allis pistons. They do not supply thicker rings to make up for piston groove ware.  Some other makes of tractors used different thickness rings on different years for the oil rings.
Example: Some Oliver 55's used 3/16 oil rings and some used 1/4" oil rings. Even though both used the 3/32" compression rings. When making an order form you would make a standard form to cover all necessary questions for all makes.
Actually for Oliver it was that way for the 77's as well.
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 8:25am
My guess is Oliver changed the ring thickness on a daily basis. They made a top notch product, but all of their changing around was hard on partsmen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 8:33am
If my memory serves me right I think that Messy Hairlip and Farmalittle had different oil ring thicknesses for the same diameter pistons on some models.  Probly others.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 8:56am
I wondered about wear in piston ring groove's. I have a set of pistons from a 230 Buda, which I suspect have worn grooves [ beyond allowable spec's]. I bought set of rings from Hasting's, but I bet they too sloppy, that said, pistons are junk? Hastings isn't about to start making rings to allow for my worn ring grooves. I do have a complete set that I believe is much better condition thankully.
Edited by Chris/CT - 07 Apr 2011 at 8:57am
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 10:06am
Hastings supplied the rings for my 20-35 and they also supplied the necessary shim rings to take up the wear in the grooves. We machined the ring grooves to clean them up square and they supplied spacer/shim rings with the standard rings to take up the wear.
They supplied the same type of setup for the Crossmotor Case that I restored.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 3:26pm
You probably won't have to get too sophisticated in your situation, but there is
some interesting stuff here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 6:03pm
Well I thank you all for this learning experience!
