paint remover?
abbaschild95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Topic: paint remover?
    Posted: 03 Apr 2011 at 10:59pm
so i was talking about sand blasting a hood (not an easy task i know) at the local coffee shop and someone mentioned that i can just get some heavy duty paint remover then pressure wash it off? is this true? is it cost effective? do i have to completely emerse or just spray it down with it? thanks!
Great-granfather's WC---- hopefully many more to come!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:02pm
Sandblasting gets the rust too. Chemical strippers don't...
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:05pm
ok thats exactly what i needed! ill just sand blast! ok question #2: do you have a special room to sandblast the big stuff or do you just do it in the open? i need to save as much sand as i can!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:12pm
I have a concrete pad next to my shop that I do my blasting on. I don't do the really large items myself. I have a blasting cabinet for the small stuff. Just remember to not breathe the dust. I think it's called silicosis that you get from the dust, not to mention the lead based paint...
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:14pm
ya i have a blasting cabinet also. ive just been doing bolts ect so far though. i need to do the hood now and im not sure how to go about doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:24pm
I clean off the pad and blast away. I use my big shop vac to pick up the sand, pour it through a screen and reuse. My hood panels are too long for my cabinet too...
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:28pm
I use a blaster I got from harbor freight..does a good job for me.  I dont have the luxury of a concrete pad outside..yet  so I use a tarp spread out, then just pick it up and funnel the sand into a 5 gallon bucket, screen it as I pour it back in the blaster.
faastmoto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote faastmoto Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 1:40am
washing off the paint is never considered to be easy. And when you get a stain on your lovely bike, it is most irritating for not being able to remove it
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 8:00am
I had two layers of paint to remove and only a little rust so I used a chemical stripper.  I brushed a thick coat on and let it sit over night.  The next day the first layer of paint was bubbled up and loose so I use a plastic scrapper to remove it then put on another coat of stripper.  Next day I used warm water and a scotch brite pad and easily cleaned off the rest of the paint and primer.  Any rust spots I used a wire wheel or the sand blaster to do those areas that needed more attention.  If I had had enough compressor to run my blast gun longer/faster I would have blasted it all.  For me the stripper was faster.
I used about 2 gallons of stripper for all the sheet metal.
Edited by Stan IL&TN - 04 Apr 2011 at 8:03am
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 8:14am
I used, for the most part, a product called AIRCRAFT brand paint remover. You spray it on the surface that you want to remove the paint from and wait about 5 to 10 minutes. It starts to break down the paint to where all you have to do is go over it with a pressure washer. But BE CAREFUL it is an acid and will burn you. But it is neutralized by water so if you get some on yourself just stick that part in a bucket of water or run some water over it.
It does an excellent job of removing paint and the rust that was left is a fairly quick job with a sander.I got lucky that my WC wasn't a complete pile of rust.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 9:25am
I am surprised that no one mentione electrolysis.  I have done two hoods.  My tank will do half the hood at one time.
This page was generated in 0.172 seconds.
