Starter tank Picture
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Topic: Starter tank Picture
    Posted: 03 Apr 2011 at 10:19am
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:34am
Fred, looks like a nice reproduction. I've always been curious about these tanks because it was an option in my ca manual. Any pics out there of a CA or any other model with starter tank? Ron
CA Tractor
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:35am
That is purty.  The tank on my 41 C , looks as good in the hood, but it was rusted so bad I cut off the bottom half.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:36am
Whats a starter tank for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:40am
The starter !!!  LOL !!! If you got a all fuel or kero set up on your trator this was the tank that your gas went in for starting the cold engine that was not up to operating temp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:44am
It is to start a tractor on gas to warm up and then switch to keorsine, or lower priced distilent, yesar ago.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:45am
Ok thats what I was thinking. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 11:52am
What engine differences were on a fuel/kero tractor? carburetion, compression? or nothing at all, just get to operating temp and switch over? Ron
CA Tractor
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 12:31pm
My understanding was that glow plugs were not around and to get the tractor to fire up in the cold was hard to do. So you started on a higher octane fuel and when up to operating temperature it would run fine on the other fuels.
Danny Raddatz
Ed in TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed in TX Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 12:51pm
I think the kerosene/distillate tractor used a different manifold to preheat the mixture. Somebody correct me if I'm wrong. I have a dual fuel B but I don't think I have the right manifold to run both fuels. Other than that I'd also like to know if there was any internal changes to the engine.
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 2:57pm
Lower compression
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 2:58pm
Also different jets and venturi in carb.
chllngr528 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chllngr528 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 3:26pm
Originally posted by everett048 everett048 wrote:
Lower compression
Why would it be lower compression? I would think it would have to be higher compression as kero is closer to diesel then it is to gasoline. If your running on kerosene the enigine would be using compression ignition instead of spark.
From what I understand the dual fuel tractors have a exaust manifold that heats the fuel. Now when you heat kerosene you lower its flash point so maybe its not running on comperssion ignition?
On the other hand I could see why they would've lowered the compression ratio as I think that kerosene has more energy then gas and that power may have reaked havoc on the bottem end.
I would like to know the answer as my WC is a dual fuel.
Edited by chllngr528 - 03 Apr 2011 at 3:54pm
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 4:09pm
Dad had a duel fuel  It had starter tank and baffle in exhaust raifdator shuter and pet cock on side of oil pan. Start up close shutter and start on gas when hot stift over from gas to kersene open shutter enough to keep heat up. End of day open pet cock drain 1 qt of oil  to get rid of blow by and add 1qt. Less power on kersene  He knocked out baffle in exhaust  run on gas had more power didn,t have to add extry oil . Was not enough difference in fuel price  to pay to use kersene and run cool and didn,t use shutter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 4:13pm
PS It was a WC  1942  on steel no starter or lights , just a mag and crank.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 4:42pm
  people were a lot mre cost conscience back then kero was lot cheaper than petro  not a noticeable difference in power  we bought man5 semi loaDS OF TRACTORS FROM FLA. 1960 MODELS TOO  was told the reason for them was the hired help would help them selves to fuel for their  trucks in the back of plantations too   they would not do that with kerosene another reason  you fellas are onlytalking about your area[huh]
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 7:05pm
This information is from my WD 45 service manual.
Danny Raddatz
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 9:18pm
I always thought that the dual-fuel WD45 was only LP and Gas. The book stated that if you ran out of one you could run on the other fuel. Bob
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 2:07pm
We have offered these starter tanks for a couple years. We have them available on our website at www.normsactractors.com or you may call me at 1-815-238-4506.
Norm
WC Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Dale Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 2:28pm
I bought a manifold at a swap once that had the angle on the right hand side of the exhaust like the one pictured on the left. This is the first time I've seen anything like it. Looks like the aircleaner with the snout coming out like that was the reason for it. Is this how WD45 air cleaners were made? The manifold I have has the standard out the side cover as for an unstyled WC.
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2011 at 3:50pm
Fred, sorry I have to ask you a question?  If the "starter tank" is to start the starter, then does Steve at B&B sell the wiring harness/fittings for this??
You guys always have the correct answers???  LOL
Tricky Dickie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2011 at 12:04pm
It's sad that so many younger collectors do not understand dual fuel, kerosene, tractor fuel or tvo tractor engines. By the way, I explain the difference between flash point and octane number and their relevance to compression ratio in my reply to another post entitled "dual fuel tractors". All my tractors are TVO fuelled machines - you can keep those diesels!
Tricky Dickie
Edited by Tricky Dickie - 05 Apr 2011 at 12:06pm
This page was generated in 0.052 seconds.
