Belly mower on a WD
thompson-52 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thompson-52 Quote  Post ReplyReply Direct Link To This Post Topic: Belly mower on a WD
    Posted: 25 Mar 2011 at 11:37am
Just wondered if it was possible to get/put a belly mower on a 50's WD?
Post Options Post Options   Thanks (0) Thanks(0)   Quote thompson-52 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 11:44am
also, may buy a "C" that already has a belly mower but I would also like to have a 3 point, do they make a 3 point set-up for those?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 11:56am
Yes to all the above. I always thought a WD was overkill for a belly mower but a lot of them have been set up with one. I think the CA makes a fine finish mower. several advertisers on this site sell a 3pt set up.
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 12:53pm
Here is a picture of my 1953 WD with a Woods L306 belly mower on it; a great mowing combo.  I plan to install factory power steeing this summer.
Here is a picture of my other mowing rig.
I plan to take this mower off and install the factory snap coupler conversion on this 1939 B.  I know it is too early a model technically, but its the only B I have.  The L59 mower deck had all new bearings installed 2 summers ago and it has only mowed 1 summer since then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thompson-52 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 1:15pm
so with the mower deck on there can you still use the 3pt and pto? or do you have to take the deck off to use it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 1:23pm
If you have the hand lift you could still use the 3 point but if the mower deck is belted up, it would have to be running to raise the 3 pt. The PTO could be used also but you would have the same situation. If you have a mower on a WD you would have to remove the pulley from the PTO shat in order to use the PTO. The C would have a belt from the side pulley.
