Brian G NY's WD Kickout
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Brian G NY's WD Kickout
    Posted: 25 Mar 2011 at 1:43am
I hope the pics come through...
Has anyone tried to make one of these?  Where and on what does the bar pivot on?  You can tell the workings of the rest of it, but where is the pivot point? Is this a plate that is on all WD's and 45's?  Or is it an add on?
Edited by Ted J - 25 Mar 2011 at 1:52am
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 6:49am
It pivots on the top pin in the first picture.  When the plow hits something the snap coupler bell gets pulled backwards.  The bottom pin in the picture hits the small plate, pivots the fork at the top forward and kicks out the hand clutch.
AaronSEIA
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 7:06am
How common are these?
David Gibson
http://www.darkecountysteam.com
1956 WD45
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 7:12am
I have sold 3 of these units in last 6 months, 2 WD style, 1 D style, there out there.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 7:17am
We had them to sell but did not.  Even though our area was a red clay rock country.  The only heavy duty rock we ran into was in Mt. Hope.  A Catholic home near Pikesville MD.  The rocks were so plentiful and big that we had to sell them a disk plow.  The release on the moldboard plows just kept breaking loose after hitting rocks.
Good Luck!
Bill long
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 11:27am
My WD has that setup on it and it works if set up right. I see the kickout bar in your pic has been welded at some time in it's life.
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 12:56pm
I just bought the WD and D series setup from Chris.  Can't wait to get them home and installed for the fall plowing.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 12:59pm
I think I have a spare laying around if anyone is looking for one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 7:26pm
Adam your inbox is full. Pm me I am interested
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 7:53pm
  they were made that way       never broke one  worked good saved many points
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 7:55pm
Michael; I have one for a WD laying around here some place. You need to get some time off next fall for my plow day. hint-hint. lol
Don
Edited by Don(MO) - 25 Mar 2011 at 7:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:04pm
Word of caution.  I have one of these on my WD45.  If you plow in third gear, and hit a rock you WILL hit the steering wheel with chest or teeth.  Either one is painful.  Experience speaking.  If you can pull a three bottom plow in third gear, you can pull four bottoms in second.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 12:19am
My dad was pulling a loaded wagon uphill once when the front tire of the wagon hit a hole. The shock caused the plow trip to pop the hand clutch out of gear even though the wagon did bounce through the hole. With the handle in neutral, the only way then was backwards. He jerked the hand clutch back into gear and everything jolted to a dead stop.
This page was generated in 0.079 seconds.
