Allis 175 hydraulics
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Topic: Allis 175 hydraulics
    Posted: 23 Mar 2011 at 5:56pm
My neighbor has a 175 that when you start it instantly the three point arms raise up even though the lever is down. I thought maybe it had air in the lines and needed bled. Could this be the problem and if so how would you go about beading it? Or am I way off on my diagnosis? Any reply's appreciated.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 6:46pm
Start spraying alot of lube around the valve stack, may have something hung up there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 8:35pm
Junkman - most likely the traction booster spool valve has the finger linkage that activates it frozen up in the position where it is depressing the valve.  See the pictures below.  They are from my Series IV D17 but should be nearly identical to a 175.  You need to push the finger back from the spool valve then free up the pivot for the finger.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 8:55pm
WOW, thanks for the pics to make the job easier. I will look at it and see if this indeed is the problem. I did not expect pics and such a good diagnosis.  I'll let you know if this is the problem. After buying my first Allis a couple weeks ago, I read this forum everyday. Thanks to all that make this a great forum.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 10:03pm
Referring to the second picture, the part that pushes against the valve is what is seized up - there is a bushing inside that is rusted up.  Best thing to do is take it apart, clean it up, and put a healthy dose of anti-seize compund.  Once back together, you will be good for many years to come.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2011 at 11:30pm
Mike you're getting a lot of mileage outa those pics!  Too bad you can't get a couple of pennies each time you post...you would be a rich man LOL!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 12:13pm
Eldon - yes I do.  I wondered myself how many times now I've used them to answer that question.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 8:49pm
Again thanks for the info. You were right a seized linkage. cleaned it up and works like new. Although it was not as grimy as the one in the picture. Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 9:45pm
Mark - glad to hear it's fixed.  I took those pics in 2006 when I had my D17 in the shop getting it's last stages of restoration and a new paint job.  So those were the last few pics of it with the grime, lol.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
