Timing cover for WD45D
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Topic: Timing cover for WD45D
    Posted: 07 Jan 2011 at 3:22pm
Does anyone know where I can get the timing cover gasket for a WD45D now. Agco no longer shows them in their books?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 4:09pm
Call Sandy Lake Imp. I'm pretty sure they are the same as a 262 in a D17D.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 4:43pm
I may have one, could make you one from mine if needed.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 4:44pm
Not the same, kinka close,   the 45D used the AmBac PSB pump which requires a larger dirve gear, so the timeing cover is made to accomodate the larger PSB drive gear.  I was stunned when I ordered the gasket, NLA.  I made one out of gasket material.  Good luck!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 4:55pm
ck with BUDA ENGINES in shreveport la he has them...
This page was generated in 0.162 seconds.
