Radiator/fuel cap
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Topic: Radiator/fuel cap
    Posted: 23 Dec 2010 at 10:34pm
One of my B's has what I would term an outside grasp radiator cap. (The ears of the cap turn and clasp over the outside of the radiator nozzle) Another of my B's have an inside grasp radiator and fuel cap. (the ears of the radiator turn and clasp into the radiator nozzle) I believe all of my gas caps are inside grasp.
Can someone help me with an explanation here? TIA
Edited by GBACBFan - 23 Dec 2010 at 10:44pm
are genuine." - Mark Twain
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2010 at 11:31pm
non presure radiators use the same type cap as the fuel tank only not vented [pre ww2 ]  modle  Bs    Presure type caps [ as you discribe ]  lock on to the out side of the radiator filler neck  and have a spring and a rubber seal  they are rated by poundage presure type caps are  mostley the same size the higher the presure the higher the boiling point   these caps wont fit fuel tanks [ unles yours has bin modifed with a rad filler neck] presure ratings are stamped o n the top of the  cap kep the presure low  on old rads 3 to 5 #
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2010 at 8:17am
Another learning nugget, pumpkin man, THANKS!
