Model B Paint
Allis1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis1 Quote  Post ReplyReply Direct Link To This Post Topic: Model B Paint
    Posted: 05 Dec 2010 at 3:23pm
Hello , I am restoring a 1940 Model B and would like to know what color paint to use ? I have used Persian #1 on another tractor and it is a very light orange compared to the original darker orange. I have not received any help from dealers and the paint company web sites show nothing. Can anyone Help??????
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 3:36pm
I dont claim to be a painter...but-what primer are you using?  I believe it can be a difference between say: a red oxide primer and a gray primer.  Also, how many coats of 'color' did you put on?  that probably would be a bigger factor than the primer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 4:14pm
Wes, I did use a light gray primer and two coats of paint. Thank You for the reply. Anyone else ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 4:42pm
Persian Orange 1 is the right color. Who mixes it and what formula they use may change things but the PPG 60080 is kinda like the standard. Are you sure the "original " color is original?  PO 1 does seem to have a lot less red to it than PO2 or Corporate Orange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 4:47pm
Here is a color chart someone posted a while back. The 2 in the middle are probably closest to PO 1 as far as these particular paints go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 6:16pm
C Tucker, Thank You for your comments and the color chart,also for the PPG Standard #. Regards, Allis1
This page was generated in 0.031 seconds.
