Burrrrr Cold ride
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Topic: Burrrrr Cold ride
    Posted: 02 Dec 2010 at 9:04am
I think it's going to be cold ride Saterday night in the light Christmas paride, went out to the shed this morning and got sweaten cranking the 1936 WC stubberen OLD-OX findly started let it run for about 1/2 hr and shut it off, and to see the carb leaking gas between the bowl and main body, hope auto value has the right kit, all I need is the gasket, if not I'll have to take CA, either way the weather forcast say 24 degree's saterday night it's going be a cold ride, but I'am kinda comitted to haul float, never did this trick before so it may be FUN.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 10:45am
Just buy a sheet of gasket material and cut your own...cheaper than buying the kit.
ALLIS EXPRESS!
This year:
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 11:52am
First try tightening the screws holding the parts together.
When making your own gasket, be sure to open the passages around the edges. Long ago, I made a carburetor gasket out of a cereal box. Worked fine.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 12:46pm
Thanks Guys, I thought about the make your own thing, yep that what I'll do.
