816 backhoe
BiG210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiG210 Quote  Post ReplyReply Direct Link To This Post Topic: 816 backhoe
    Posted: 13 Nov 2010 at 12:12pm
is $7500 to much for one it needs new bushings and pins in hoe loader and swing cyl. it also needs a bottom in the front bucket has 3 other hoe buckets and needs the fuel system gone through to fix leeks and all cyl. have leeks to. no cab just a rops.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 1:36pm
Depends on if everything works and how bad the leaks. If rods are good on cylinders , seals are not bad to replace but if rods are pitted then looking at cost, pins and bushings can get expensive if wear is beyond bushing and holes are deformed.
 I paid a little more for my 715B but that was 15 years back and made that back many times over.
