WC Sherman Underdrive for sale |
Larry Swenson
Joined: 13 Sep 2009 Location: Easton, MN Points: 610 |
Topic: WC Sherman Underdrive for salePosted: 12 Nov 2010 at 10:48am |
For Sale: WC Sherman underdrive for tractor pullers. $500.00.
Located in southern Minnesota. Ph.507-787-2338 (leave message if we aren't here). Email: Lswenson@bevcomm.net |
Dutchboy Johan
Joined: 14 Sep 2009 Location: Netherlands Points: 571 |
Posted: 12 Nov 2010 at 2:43pm |
What's a WC Sherman??
---> Better by Design <---
Johan Straver, Almkerk/ Netherlands Allis-Chalmers 190XT Ser.III #26829XTD |
AllisChalmers37
Joined: 11 Jul 2010 Location: London,KY Points: 1846 |
Posted: 12 Nov 2010 at 2:55pm |
it is an auxiliary transmission that takes the WC from having 4 gears that are all very slow to having a higher number (7??) of forward and 2 reverse. It gives you a gear in between the ones on the stock transmission. It helped when time to use equipment at certain speeds and you wouldn't want to set the tractor at full throttle or at idle to keep that speed. It also boosted the 9.5mph top speed to, what the ad said, 14mph.
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 12 Nov 2010 at 3:48pm |
A TANK !! LOL
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 12 Nov 2010 at 5:15pm |
Larry has an underdrive which would make all normal gears slower. You would have to have overdrive to make the tractor go faster.
AllisChalmers37
Posted: 12 Nov 2010 at 5:23pm |
oops! LOL
Larry(OH)
Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Posted: 13 Nov 2010 at 7:19am |
i need a gear for the rear of an overdrive. Bought one at a sale ans is missing the rear gear. This is the one that always comes up missing when removing them. Also, mine is the wide gear, not the earlier, narrow one. Hell, I'd even make someone a deal on it for a drop box!!
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4812 |
Posted: 13 Nov 2010 at 7:27am |
What is the gearing difference with an underdrive, I've heard 25% on the overdrives?
DrAllis
Posted: 13 Nov 2010 at 7:35am |
I've always figured it was the same split in ratios...either up 20-25% or down 20-25%. The underdrives were used for mounted cornpickers so you had a slower "low" gear and also a slower than road gear speed so it was between regular 3rd and regular 4th.
MNLonnie
Posted: 13 Nov 2010 at 7:39am |
If I used my Speed Patrol more I would like to slow it down but I'm not sure 25% would be enough, 50% would be ideal.
Breeze
Posted: 13 Nov 2010 at 7:42am |
Is it Allis specific, or possible to plate it to any other brands?
ALinIL
Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
Posted: 13 Nov 2010 at 12:16pm |
Question - Can the gears be flippped in a underdrive unit to make it a overdrive unit?
RyanTN
Joined: 12 Sep 2009 Location: Stewart Co, TN Points: 415 |
Posted: 13 Nov 2010 at 12:50pm |
Not trying to hi-jack Larry's post, but no Al- you cannot swap the gears around in a Sherman transmission.
AllisChalmers37
Posted: 13 Nov 2010 at 4:34pm |
I've seen and heard of Shermans being put into the Ford N series.
Brad MI
Joined: 12 Sep 2009 Location: Arcadia MI Points: 339 |
Posted: 13 Nov 2010 at 4:47pm |
Sherman tranny's were available for many tractors including the B/C/CA and WC/WF Allis' tractors. No, they are not interchangeable they were made specific to each tractor. I have a CA with one and a WC unit on the shelf. If I remember correct my WC/WF unit is a step-up.
MNLonnie
Posted: 13 Nov 2010 at 5:12pm |
I wonder if different tractors had different geared under/overdrives because my 2N has an underdrive and I'm pretty sure it's 50%.
Andy in Central IA
Joined: 13 Sep 2009 Location: Central Iowa Points: 19 |
Posted: 13 Nov 2010 at 5:59pm |
I have one of the units. How do I tell if it is a step up or step down? Would anyone like to buy it?
Andy Central IA
MNLonnie
Posted: 13 Nov 2010 at 6:03pm |
I've never had one off the tractor but there should be an input and output shaft. Turn the input 1 rotation and see if the output turns more or less than 1 turn.
Andy in Central IA
Posted: 13 Nov 2010 at 6:07pm |
I will see if I can try that tomorrow afteer I dig it out.
Andy Central IA
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1961 |
Posted: 13 Nov 2010 at 9:39pm |
The housings are the same, but the gears are different from and underdrive to an overdrive, you can't just reverse the existing gears.
Larry(OH)
Posted: 13 Nov 2010 at 10:19pm |
I have some info on them with tooth counts for top and bottom gears. Barney helped me with what I have, but I cannot find the gar I need.
Jfrey2040
Posted: 28 Feb 2019 at 8:51am |
Hi I know this is a complete long shot but just wanted to see if there was a under drive transmission still out there thank you.
Unit3
Posted: 01 Mar 2019 at 7:18pm |
The man that bought our WC new in '36 had an under drive installed. Low gear was to fast for his combine. We had a plow day some years back. I was in behind a styled WC. He pulled in 2nd. I pulled in the low side of 2nd. He pulled away from me, until I shifted to 3rd low range. Oh, the fun you can have with a WC and a two speed rear end.
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2077 |
Posted: 01 Mar 2019 at 7:32pm |
I always wanted to add one to my CA. Seems like no body wanted to sell. All I got was "I got one & you can't afford it".
Sure would be nice for me just adding the 6" of extra leg room. I could go back to the pan seat again. |
Thanks & God Bless
Dennis |
