PTO hand clutch 6080
rowtooe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowtooe Quote  Post ReplyReply Direct Link To This Post Topic: PTO hand clutch 6080
    Posted: 29 Oct 2010 at 10:15am
I just bought a tired 6080. I can't engage Pto with tractor running. It just grinds...I have tried to adjust the hand clutch, Pto will almost stop ,  I have no more adjustment. Pto still turns but with my hand and very little force I can stop the pto from turning. The fellow who owned the tractor before me said that he always had trouble with it.. Any suggestions? Thanks Pete..
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 10:32am
The Engagement lever on the left side has adjustment, make sure it is freely moving up and down. This is a common issue on the 6000 series.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 12:04pm
I forgot to add that we had to remove the engagement plate and redo the fork in there as it had bent from the years of using it.
Snicks right into PTO gear now.
I think this was a poor design by AC
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowtooe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 12:10pm
Where are the forks? I don't under the engagment plate is that just to keep the pto lever up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 6:57pm
that engages the PTO gear. I will see if I can find a parts picture
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 10:00pm
You may have to cut some off the adjustment screw on the right side to move it futher or split the tractor and adjust fingers on clutch.
 Always leave the hand lever forward when not using PTO.    MACK
